21 Pages «<7891011>»
John Passmore Options
John Passmore
#161 Posted : 28 January 2015 13:49:53
Hi Everyone
For those following the saga of the stern-post, problem solved...BigGrin
I decided to make a new one and after two attempts the 3rd prototype is shown below "the real thing" in the photo below. It fits perfectly in the stern slot and the difference in size can clearly be seen...Cool Cool
I would be interested to know if anyone else comes across the same problem.BigGrin
Regards to All
JohnP
John Passmore attached the following image(s):
#162 Posted : 28 January 2015 23:07:50
Great to hear you have the problem resolved John, nicely done....Cool Cool .. Thing about these kits is they have to be built, you cannot just simply glue the pieces together, you have to identify and fix potential problems. In this instance you have done this very well....Cool Cool
John Passmore
#163 Posted : 31 January 2015 04:07:46
Hi Alan
Thank you for the compliment and the advice...BigGrin
Yes I just assumed that a piece of kit with a designated part number would be more precise both in shape and dimension...another lesson learned...BigGrin BigGrin
I shall be more aware from now on and check all designated parts well in advance ...Cool Cool
JohnP
John Passmore
#164 Posted : 03 March 2015 14:46:16
Hi Everyone
Not a lot of progress for the month of Feb 2015:
Still working through issue 37 - installation of the white planks - which I feel are more awkward in some respects than the bamboo planks, as the full length ones tend to want to lift by the edges, especially on the curved areas of the hull...Blink
Some of the photos below show some solutions to the problems...Cool
Different solutions for different areas of the hull...Cool
Just a few more planks to completion, then to tidy up under the transom.
I have up to issue 51 now so plenty of work in the offing...BigGrin BigGrin
Regards and happy building to all...BigGrin
JohnP
#165 Posted : 03 March 2015 19:29:10
She's looking good John, nicely done...Cool Cool... Will admit, that area around the transom also gave me problem, it is a very tricky area to get just right.... Cool .. Look forward to seeing the hull finally planked.... Cool Cool
Hans
#166 Posted : 05 March 2015 11:24:43
Lovely job there John, nice clean lines. Problems help us to be stronger for the next time round. Well done.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
AdamHall
#167 Posted : 05 March 2015 14:34:19
John, I thoroughly enjoyed catching up with your build progress, especially how you worked through and resolved your stern post issues.
Each individual build seems to have its own unique aspects that require more attention. A credit to you for sharing these and how you have resolved the problems along the way.
Amazing work.
BZ
Adam
John Passmore
#168 Posted : 29 March 2015 11:37:18
Thanks for looking in and the compliment Alan...BigGrin
I think I got the transom planks just about right in the end...Cool
See my March progress report below...BigGrin
JohnP
John Passmore
#169 Posted : 29 March 2015 11:39:05
Hello Hans
Thanks for looking in and the nice words...BigGrin
JohnP
John Passmore
#170 Posted : 29 March 2015 11:44:44
Amazing work.
BZ
Adam
G'day Adam - how'yr going?...BigGrin
I've had a look at your build and must say it looks immaculate...Cool
My March progress pictures are below.
JohnP
John Passmore
#171 Posted : 29 March 2015 12:24:04
Hi Everyone
Here following is my progress for March 2015...Cool
week 1
Tidied up white planks under transom...Cool
Completed installation of White planks...Cool
Installed transom panel and Stern gallery decks...Cool
week 2
Completed fitting of brown planks to hull...Cool
Prow and keel plates fitted...Cool
Stern post fitted...Cool
Freeboard painted black both sides...Cool
week 3
Hull painted in accordance with Issues 39 and 40, using a number 4 brush as I don't have one of those air thingies...Cool Painted 4 coats of each colour to get that solid look. I am a bit concerned the red and white looks a bit bright and vivid but hopefully this effect will be a little more subdued by the addition of future fittings and accoutrements...Cool
Painted black and fitted gunwales starboard side only...Cool
week 4
Painted and fitted gunport linings to the Starboard side only... all the port bottom edges first, then inverted the ship and did all the top edges - followed by all the side edges...Cool Initially lost a few pieces forever by dropping them inside the hull, but once a Modus Opperandi was worked out things went
quite smoothly...BigGrin
Happy Building to All
JohnP
jonny7england
#172 Posted : 29 March 2015 12:27:02
Beautiful work there John...Well done mate!! Wink ThumpUp
John Passmore
#173 Posted : 29 March 2015 12:56:15
Thanks for the kind words Johnny...yeah! a lotta hard work there...BigGrin
JohnP
#174 Posted : 29 March 2015 15:34:36
BigGrin Lovely work John can't what to see more ThumpUp
#175 Posted : 29 March 2015 17:37:25
John
Lovely work. It's beginning to look nice and colourful now.
Hope the rest of your build goes well.
#176 Posted : 29 March 2015 19:31:36
HI John, BigGrin
Very impressive. Cool
Looking really good and the encapsulated nuts for the stand are working well. I`ve built them into my sots build, but have yet to make the stand.
Had thought of the possibility of making a pivoting / swinging base to tilt the hull to make working easier. What do you think?
Keep up the good work. Cool Cool
#177 Posted : 29 March 2015 19:43:11
Very Tidy looking build John, will look awesome when it's finished
#178 Posted : 30 March 2015 00:11:15
You've certainly moved her along in the past month John and a cracking job you are doing too.... Very nicely done indeed, well done that man....Cool Cool
John Passmore
#179 Posted : 30 March 2015 04:18:54
Thanks Martyn. You won't see any more till the end of next month....Laugh Laugh
JohnP
John Passmore
#180 Posted : 30 March 2015 04:23:05
birdaj2 wrote:
John
Hi Tony
Thanks for looking in and the compliment. Methinks it's looking a bit TOO colourful, but we'll wait and see...Cool I'm following the magazine steps closely at the moment...BigGrin
JohnP
This page was generated in 0.618 seconds.
