Need to remove glued parts Options
dbartonjr
#1 Posted : 03 March 2015 18:10:08
I do not know how it happened but my measurements are off by 10mm in placing the two front gun bases on the deck.javascript:insertsmiley('Cursing ','/images/emoticons/msp_cursing.gif') I have removed glue before from the hull when I installed the wrong frame part but given where the gun bases are placed I am not sure if steam will not cause more harm then good. Does anyone have any other suggestions. FYI, it is wood glue that I used.
Thanks in advance.
Best Regards,
Dan
Current Builds: Yamato
On the Bench: Akagi, USS Missouri
#2 Posted : 03 March 2015 19:33:58
Thanks in advance.
Best Regards,
Dan
Hi Dan, am not able to see your picture unfortunately but rather than steam and providing you have used wood glue then I would try hot water, applying around the glued area using a small paint brush, that should soften the glue enough to enable you to remove the offending part without causing to much trouble to the surrounding area.
Hope this helps..
#3 Posted : 04 March 2015 20:17:34
Hi DB
I agree with Alan use a brush to get the hotish water under the gun bases it should free them with out too much trouble
