12 Pages «<7891011>»
Del`s build of the AVRO LANCASTER 1:32 scale Options
#161 Posted : 02 March 2015 14:18:38
Wow great progress Derek Cool
#162 Posted : 02 March 2015 18:57:51
Hi Spal, BigGrin
Many Thanks for looking in.Cool
Looks like a lot to do before the next update, but will be worth the wait, as when the basics are done, this kit takes off with the detail and that is immense.
#163 Posted : 02 March 2015 19:41:38
Shauncnh
#164 Posted : 02 March 2015 20:33:29
Looking great, keep up the hard work.
Regards Shaun
Building-RC spitfire
Shauncnh
#165 Posted : 08 March 2015 16:15:58
Hi Derek, I also have this same kit and am thinking of making a start on it. On the DVD with the kit it shows using pva glue but in the instructions it says to use gel super glue for gluing the wooden frames together, just wondering which glue you have been using?
Regards Shaun
#166 Posted : 08 March 2015 17:40:25
Hi Derek,
Good update thanks for showing us, tell me Derek am I correct in thinking that it has a metal skin plates with rivet marks.
Trev.
#167 Posted : 08 March 2015 23:19:20
Hi All, BigGrin
Firstly thanks to all above for taking the time to look in and the kind comments. Cool
Now for the questions:
Shaun, I don`t have the DVD but my choice for adhesives is as follows:
A quick grab Aliphatic for the ply parts and large amounts of superglue gel for the nylon/plastic stringers.
Have yet to decide which glue to use for the metal plates as they are stuck to the stringers and ply frames, so quite a combination of materials.
That said, I will be using only a small portion of the plates as the interior detail is wonderful and it would be a shame to lose it out of sight.
Hope this helps at least to get you started.BigGrin
Trev, You are totally correct.
This baby can be fully skinned with what I take to be Ali plates, but as said above I won`t be using them all by any means.
As for the rivet markings, yep for sure by the thousands if you fully skinned it.
The interior detail is such that the ply floors are Ali plated with full rivet markings. The rest of the interior detail has to be seen to be believed, but more on that at a later date.Flapper
Have been busy today constructing the right outboard wing section and the split trailing edges for both the right and left wings.
So update to follow shortly. Watch this space. LOL
#168 Posted : 09 March 2015 17:31:32
Hi All, BigGrin
Here`s the latest update of my Lanc build.
This update covers the build of both the inboard split trailing edge rear wing sections.
Only the main frame sections are built at this stage, the pivoting part of the trailing edges are built at a later stage.
So here`s the parts for the port side.Pic 1
First thing to notice is that the orientation of part 198 is crucial.
The slots for the ribs are not all equally set apart.
The instructions start with the addition of an end rib.
This MUST be set at 90 degrees to the back plate, as these sections will eventually be fitted between other parts with limited space at each end.Pic 2
The instructions tell you then to fit the rest of the centre ribs in a sequential order and check they are all set at 90 degrees.
I chose to set the opposite end rib first. Also at 90 degrees.Pic 3
My preference now is to glue and fit all the centre ribs at the same time and then using part 199 as a spacing template to get all the ribs to set at the same time. They are also then guaranteed to be set correctly when the trailing edge plate is put in place.
Having cut out and cleaned up the edges of the centre ribs, glue and fit them in turn to achieve this result.Pic 4
When all the ribs are in place take part 199 and without glue hold the centre ribs in place as follows.Pic 5
I use a quick grab Aliphatic glue for the ply parts of this build and I still had enough time to get these parts set in place before the glue dried fully.
If you use the instructions method you will have ten setting and drying times to obtain the same result I achieved in three. That said you must work with what you are most comfortable with.
With the ribs set in place and dried, it`s time to fit the trailing edge plate that I used as a template.
I applied glue to the eight centre ribs where the plate is laid on them and allowed it to set. The two outer ribs still have a little bit of flex in them to allow them to be moved outwards slightly so you can apply glue between the outer ribs and the ends of the trailing plate.Pic 6
The last part to be added is a centre spar.Pic 7
Apply glue to each of the slots the spar will sit in and place it with one end square to an outer rib, then allow to set.
When set trim and sand the overhanging end of the spar to achieve this.Pic 8
The trailing edge plate now needs to be sanded to take the shape of the rib ends. This is only a small amount of sanding and unfortunately I`ve been unable to get a picture to show the detail, but the instructions show it well enough.
Well that`s the port side done.
The starboard side uses the exact same method as the port side.
There are though some differences in the parts supplied.
Watch the orientation of the main plate the ribs are fitted to or the life raft box section will not fit.
Here`s the parts.Pic 9
When the frame is constructed as before you get this result.Pic 10
Part 196 is now added to start the life raft box. Apply glue to the ribs it will sit on and hold in place.Pic 11
Two more parts are now added to complete the box section, but NOTE they are different sizes.(Only slight but they are different).
Fit part 197a toward the back of the box looking from the thin edge of the part being built.Pic 12
Now fit part 197b to complete the box section.Pic 13
So, that done here`s where I`m up to.
These two sections are identical in size, it`s the camera angle that makes them look different.Pic 14
Finally, this last picture gives you an indication as to where these parts will finally fit.Pic 15
That`s all for now folks,
Happy Building.
michu
#169 Posted : 09 March 2015 17:40:38
This looks great - can't wait to start my own build :)
Happy building :-)
#170 Posted : 09 March 2015 18:06:25
Hi Michu, BigGrin
Many Thanks, Cool
Will follow your build with interest, but don`t forget I`m jumping around this build so far from part 1 to 79. So if you do it in order it won`t get so big so quickly.
You`ll still love it whichever route you choose.BigGrin
Please let me know when the parts arrive.
#171 Posted : 09 March 2015 18:19:09
Another great update Derek and a top tip with the glueing ThumpUp
#172 Posted : 09 March 2015 18:35:22
#173 Posted : 09 March 2015 18:48:14
Nice work Derek, she's certainly coming together now - you'll soon be painting those 500lb GP bombs and loading 'em up for Dresden!! Cool ThumpUp
Kev BigGrin
#174 Posted : 09 March 2015 18:54:36
Hi Dave, BigGrin
Thanks for looking in. Cool
Just realised I missed out a section of the last update. Blushing
I have actually built the basics of the second outer wing section and to that end, as it`s just a mirror of the first outer wing section I`ll put up a couple of total build pictures.
The wing tips are just laid in place as not constructed yet and the props laid in place for effect.Pics 1+2
Still got the rear gunner section to finish along with the tail section, to give the full realisation of it`s length, but that`s where I`m at.
Shauncnh
#175 Posted : 09 March 2015 18:59:43
Hi Derek,
That's one impressive looking model and can't wait to start my own. Also thank you for the advice on which glues you are using. Can't wait to see the rest of your build.
Regards Shaun
#176 Posted : 09 March 2015 19:08:51
Shauncnh wrote:
Hi Derek,
Regards Shaun
Hi Shaun, BigGrin
Thanks for your comments and the good thing is that advise on this great forum always comes free. Cool
#177 Posted : 10 March 2015 00:41:09
More wonderful work Derek, I'm really impressed with this kit and can readily see why you decided to take it on, well done you.... Gets better and better with every post you make....Drool Love Drool Love Drool .. Looking forward to the next update...
#178 Posted : 10 March 2015 14:12:03
Hi Alan,BigGrin
Many thanks for the comments.Cool
Having got a majority of the airframe built, I now have an awful lot of nylon/plastic stringers to fit. Crying Crying
The good news is that to stop myself going stringer crazy, there`s loads of detail parts to be built and added to the frames.
Then, in between times I`ve still to decide how much coverage to put on the build. I`m deferring this decision for a while till I see how it all starts coming together.
Next update, not to far off I hope.
michu
#179 Posted : 21 March 2015 13:35:09
Hi Derek,
I ordered this CD yesterday - http://www.flyingzonedir...drom/lancasterindex.htm - and it already came in the post today. Spent last hour drooling over detailed images, it's a wonderful wealth of reference material - and not very expensive too. Very much recommended before you get to detailing stage! :)
Happy building :-)
#180 Posted : 21 March 2015 16:58:10
Hi Derek this a superb build you have there looks fantastic. Very well done indeed.would have taken this on meself but just not anywhere could put it safe as have 9 cats here.enjoy following your build very much though.cheers mick.BigGrin BigGrin
This page was generated in 0.255 seconds.
