Very neat work, well done
Very nice work Terry, it's going to look great when finished
Lovely work, if this is a sign of things to come then this will be a stunner Steve
 Nicely done, a couple of coats of varnish will bring out the colour too Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
No that is seriously nice work there Terry, superb detail....  .. Very well done.... Will definitely be following you progress.... Regards Alan
They look great well done “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 08/01/2015 Posts: 68 Points: 178 Location: Holland
Thanks Boys, your comments are a great inspiration. Happy modeling.........Terry On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
Hi Boys, just started to fit Hull Planking, this time I'm using PVA wood glue instead of UHU it may be more time consuming but gives a stronger and more flexible fix. What experience have you had? Happy Modeling........Terry Terry Benson attached the following image(s): On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
Good Morning, whilst the hull planking dries I have been completing the aft cabin. Happy modeling. Terry Terry Benson attached the following image(s): On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
Lovely work Terry, it's really coming together nicely
Hey Boys, couldn't bend the aft hull planks so I laminated a section, worked perfectly Terry Benson attached the following image(s): On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
Certainly taking shape now Terry, think you are doing a great job of her... Keep up the great work and keep those pics coming.... Regards Alan
Thanks for all your comments I find them a great inspiration, as a carpenter I'm used to handling 3x2inc not millimeters I've now finished the hull planking and are ready for my favorite bit sat in the garden sanding. Happy Modeling.........Terry Terry Benson attached the following image(s): On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
Joined: 24/02/2013 Posts: 212 Points: 632 Location: denmark
Hi Terry your model looks great  . and I find your solution with laminate just right I will follow your project with great interest
Thanks Samson, Finished sanding and now ready for paint job. I am going to paint her as close to the original as possible which means ignoring the makers instructions, here hoping Happy modeling.......Terry Terry Benson attached the following image(s): On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
Beautiful work Samson  The shape of the hull will make very easy work if you were to use copper tape for the tiling. Look forward to more. Steve
Hi Terry. Very nice work on your cabins. Look forward to seeing more of your build Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Very nice work Terry, looks nice and smooth
Guest (11)
