late start build Spitfire Options
Ron
#1 Posted : 20 February 2015 16:06:56
Rank: Amateur Level 1
Hi ,if I was to start the Spitfire build this year 2015 ,would allthe parts be available ,as I know that it has been running for quite a time.
regards ron
#2 Posted : 20 February 2015 16:30:35
Hi Ron,
Even if the Spitfire goes out of stock during your subscription period there will still be enough parts allocated to current subscribers for you to complete the build.
So basically, if it's showing as in stock then this means for the length of the subscription.
Ron
#3 Posted : 20 February 2015 16:45:12
Thank you for the quick reply Stevie_o, very kind of you ,will go about ordering and start,
Regards Ron
This page was generated in 0.097 seconds.
