Joined: 01/11/2011 Posts: 37 Points: 101 Location: London
And my first attempts at planking:  Don't know why, but I really enjoy this part
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
told you it would look good. Definately worth it HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
Nice work Astro  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 06/08/2011 Posts: 480 Points: 1,421 Location: Galway
Good job, Am looking forward to seeing your progress Ger
Ive finally got around to cutting the gun ports. Was so paranoid that I marked up, erased and marked up again at least 6 times until I was happy. As I'm doing the 28 month build, there's a bit of a lull at the moment until I get the sapelle planks for the hull, which I hope to receive in the next installment, whch is my number 6 due in 3-4 weeks! I'm going to add some LED lighting too, to help pass the time.
Hi Mate, Looking awesome upto now.. Keep it up, Just a quick note, When u pin the planks knock the pins in half way to hold the plank then remove the pins and trenail or get brass pins as the A/L pins are steel and when u sand the planking down it discolours round the pin giving a dark area. If you can try not to use any pins. Look on my build you will see how I planked without pins and the way I clamped the planks down. Happy Building Chris... On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi all I've been away from model making for a while but have lately picked it up again. The following are some pics of my Surpise and where I am at the moment. astronut01 attached the following image(s):
Still got a bit of cleaning, painting and some remedial work but am quite happy with the way things are going. astronut01 attached the following image(s):
I've just cut the the gun port openings and am busy tidying things up atm.
Thought I'd also post some pics of the various stages since I was last online astronut01 attached the following image(s):
Messy job! astronut01 attached the following image(s):
Gun ports cut astronut01 attached the following image(s):
Some general shots astronut01 attached the following image(s):
The hull astronut01 attached the following image(s):
Really struggled here. Didn't think much of the instructions. astronut01 attached the following image(s):
Bits and bobs astronut01 attached the following image(s):
