3 Pages <123>
Astronuts HMS Surprise Options
astronut01
#21 Posted : 21 February 2012 14:24:04
Rank: Amateur Level 1
And my first attempts at planking:
Don't know why, but I really enjoy this part
moriarty
#22 Posted : 21 February 2012 14:39:58
told you it would look good. Definately worth it
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
#23 Posted : 21 February 2012 14:56:00
Nice work AstroBigGrin Regards MikeBigGrin
Ger C
#24 Posted : 21 February 2012 18:06:00
Good job,
Am looking forward to seeing your progress
Ger
astronut01
#25 Posted : 23 April 2012 14:29:03
Ive finally got around to cutting the gun ports. Was so paranoid that I marked up, erased and marked up again at least 6 times until I was happy.
As I'm doing the 28 month build, there's a bit of a lull at the moment until I get the sapelle planks for the hull, which I hope to receive in the next installment, whch is my number 6 due in 3-4 weeks!
I'm going to add some LED lighting too, to help pass the time.
#26 Posted : 23 April 2012 15:20:42
Hi Mate,
Looking awesome upto now.. Keep it up,
Just a quick note, When u pin the planks knock the pins in half way to hold the plank then remove the pins and trenail or get brass pins as the A/L pins are steel and when u sand the planking down it discolours round the pin giving a dark area. If you can try not to use any pins. Look on my build you will see how I planked without pins and the way I clamped the planks down.
Happy Building Chris...
astronut01
#27 Posted : 10 February 2015 13:50:34
Hi all
I've been away from model making for a while but have lately picked it up again. The following are some pics of my Surpise and where I am at the moment.
astronut01 attached the following image(s):
astronut01
#28 Posted : 10 February 2015 13:52:48
Still got a bit of cleaning, painting and some remedial work but am quite happy with the way things are going.
astronut01
#29 Posted : 10 February 2015 13:54:43
astronut01
#30 Posted : 10 February 2015 13:55:59
astronut01
#31 Posted : 10 February 2015 13:57:39
I've just cut the the gun port openings and am busy tidying things up atm.
astronut01
#32 Posted : 10 February 2015 14:08:25
Thought I'd also post some pics of the various stages since I was last online
astronut01
#33 Posted : 10 February 2015 14:08:55
Messy job!
astronut01
#34 Posted : 10 February 2015 14:10:49
Gun ports cut
astronut01
#35 Posted : 10 February 2015 14:11:22
Some general shots
astronut01
#36 Posted : 10 February 2015 14:13:05
The hull
astronut01
#37 Posted : 10 February 2015 14:14:14
astronut01
#38 Posted : 10 February 2015 14:15:20
Really struggled here. Didn't think much of the instructions.
astronut01
#39 Posted : 10 February 2015 14:16:20
astronut01
#40 Posted : 10 February 2015 14:17:34
Bits and bobs
3 Pages <123>
This page was generated in 0.311 seconds.
