33 Pages «<2526272829>»
willz buildz Options
willz
#521 Posted : 08 February 2015 11:26:23
OK on with the planking, after finishing the planking on the sides I next plank the stern and trim off all the access, this will make the joint stronger at the stern when the second planking is applied.
willz
#522 Posted : 08 February 2015 11:27:54
willz
#523 Posted : 08 February 2015 11:40:06
Started the second planking and decided to put in a stripe at the top, I`ve seen an old painting with this and also some models have it, after researching small boats looking for details on this build think we have pretty much a free for all on the colours, as you can see by the photo I use the same method, I glue the plank on the bow, leave to dry then glue the remainder down
#524 Posted : 08 February 2015 12:54:39
Jesus-Belzheim
#525 Posted : 08 February 2015 16:10:12
Looking good Willz BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#526 Posted : 08 February 2015 23:00:44
From bits of scrap you are producing special, wonderful show of skill....Cool Cool
#527 Posted : 09 February 2015 17:10:58
Hi Wiltz.
Superp work.
Looks realy great.
Ian Cool Cool BigGrin
willz
#528 Posted : 10 February 2015 03:43:45
Cheers lads appreciated, as for the state of the bits in the box stevie-o I`m sure plenty of us have had something similar, anyhow on with the build, as I continue with the second planking I file the planks to get as near parallel to the keel as possible, on my other two scratch boats always had to put in funny short bits at the end or in the middle, getting closer not there yet, the photo shows where I am, its the last plank that will be tricky
Hans
#529 Posted : 11 February 2015 06:36:42
As usual, sterling job there Willz. Really looking great. Your skills just seem to be getting better and better.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
karl josef
#530 Posted : 14 February 2015 20:52:16
willz,Looking good
Best regards,
Reiner
mark 2
#531 Posted : 15 February 2015 07:46:23
Hi Willz BigGrin .
I would just like to say what a fantastic inspirational build you have done.
Best regards.
z8000783
#532 Posted : 15 February 2015 11:21:24
Groups: Unapproved
I agree with Mark, thanks willz.
willz
#533 Posted : 16 February 2015 23:33:28
Thank you all for your kind comments appreciated, finished the second planking on the launch, at this point we can safely remove the internal ribs because the second planking has laminated the boats shape, as you can see by the photos I dont put in too many ribs, only enough to hold the shape, more at the front to form the curve, the boat is very strong with the ribs removed, this allows us the freedom to work on the internal details, etc.
#534 Posted : 17 February 2015 08:26:48
Drool Wow stunning work on the ships boat willz simply lovely BigGrin Rgd Martyn
sparks
#535 Posted : 02 March 2015 21:08:46
Great work Willz Drool
#536 Posted : 02 March 2015 21:33:36
#537 Posted : 02 March 2015 22:32:36
Simply fabulous....Drool Drool
Hans
#538 Posted : 03 March 2015 12:48:03
Stunned into silence.
Rgds, Hans
willz
#539 Posted : 20 August 2015 05:23:10
Hi everyone, long time, had a break and now starting to get the itch again, not done much but having second planked most of the ship my thoughts concentrated on how to tackle the wales, I decided to have the wales in the stock type shape of the original ship, so here`s a set of photos showing how I went about it, not done the bottom one yet so only explaining how to cut the symmetrical one!
Its all done on a jig made from a scrap piece of 6mm ply.
First I cut a handful at just over the correct size then place in the jig overlapping the stop, this ensures that my first cut end is square and true.
Second twirl the piece round putting the trimmed square edge up to the stop and cut again, this gives us the piece at the correct length, (not going to go into measurements its all relevant to the individual scale)
next using the same piece of ply I made the jig for the angles, again place in jig cut once twirl round and cut again.
Using this jig method means you never have to change the fence on the saw to complete the stock shape piece, all settings are in the jig, I only cut enough for one side so when I want some more I just dig out the jig and if need be just set the saw fence into the saw cut thats in the jig, cheers
willz
#540 Posted : 20 August 2015 05:26:56
photos not working have a look into this later
This page was generated in 0.383 seconds.
