OK on with the planking, after finishing the planking on the sides I next plank the stern and trim off all the access, this will make the joint stronger at the stern when the second planking is applied. willz attached the following image(s):
Started the second planking and decided to put in a stripe at the top, I`ve seen an old painting with this and also some models have it, after researching small boats looking for details on this build think we have pretty much a free for all on the colours, as you can see by the photo I use the same method, I glue the plank on the bow, leave to dry then glue the remainder down willz attached the following image(s):
Lovely work Willz, that shot of the open kit box is a thing of nightmare's  Imagine if that had just arrived in the post! Steve
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Looking good Willz
From bits of scrap you are producing special, wonderful show of skill.... Regards Alan
Hi Wiltz. Superp work. Looks realy great. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Cheers lads appreciated, as for the state of the bits in the box stevie-o I`m sure plenty of us have had something similar, anyhow on with the build, as I continue with the second planking I file the planks to get as near parallel to the keel as possible, on my other two scratch boats always had to put in funny short bits at the end or in the middle, getting closer not there yet, the photo shows where I am, its the last plank that will be tricky willz attached the following image(s):
As usual, sterling job there Willz. Really looking great. Your skills just seem to be getting better and better. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
 Rank: Pro   Groups: Joined: 01/01/2013 Posts: 149 Points: 459
willz,Looking good Best regards, Reiner
Hi Willz  . I would just like to say what a fantastic inspirational build you have done. Best regards. Mark
I agree with Mark, thanks willz.
Thank you all for your kind comments appreciated, finished the second planking on the launch, at this point we can safely remove the internal ribs because the second planking has laminated the boats shape, as you can see by the photos I dont put in too many ribs, only enough to hold the shape, more at the front to form the curve, the boat is very strong with the ribs removed, this allows us the freedom to work on the internal details, etc. willz attached the following image(s):
 Wow stunning work on the ships boat willz simply lovely  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Joined: 01/04/2013 Posts: 342 Points: 1,029 Location: Essex
Great work Willz Regards Alan England expects that every man will do his duty.
The launch is perfect Willz, would you mind if I send you all my ships boats to build? Steve
Simply fabulous.... Regards Alan
Stunned into silence. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hi everyone, long time, had a break and now starting to get the itch again, not done much but having second planked most of the ship my thoughts concentrated on how to tackle the wales, I decided to have the wales in the stock type shape of the original ship, so here`s a set of photos showing how I went about it, not done the bottom one yet so only explaining how to cut the symmetrical one! Its all done on a jig made from a scrap piece of 6mm ply. First I cut a handful at just over the correct size then place in the jig overlapping the stop, this ensures that my first cut end is square and true. Second twirl the piece round putting the trimmed square edge up to the stop and cut again, this gives us the piece at the correct length, (not going to go into measurements its all relevant to the individual scale) next using the same piece of ply I made the jig for the angles, again place in jig cut once twirl round and cut again. Using this jig method means you never have to change the fence on the saw to complete the stock shape piece, all settings are in the jig, I only cut enough for one side so when I want some more I just dig out the jig and if need be just set the saw fence into the saw cut thats in the jig, cheers willz attached the following image(s):
photos not working have a look into this later
Guest (5)
