6 Pages «<456
Nems 1:16 T-34/85 Options
#101 Posted : 06 February 2015 22:14:31
Superb realism Daran, I feel like I want to take one of those shells out of the rack and shove it into the breach and I can almost smell the oil, diesel and cordite fumes!! Cool Drool ThumpUp
Keep up the great work my friend, a fine piece of engineering!!
#102 Posted : 06 February 2015 23:19:36
Thanks for the comment Kev, think there may be a battle in the display case with the Tiger and the T34/85!!LOL LOL
Breach and barrel are now fitted to the upper hull, just the shells to paint and fit, bit of dusty stuff and then I can glue the 2 halves together!!BigGrin BigGrin
#103 Posted : 07 February 2015 09:50:11
Shells done and fitted in the rack, the two halves of the turret glued together.
#104 Posted : 07 February 2015 20:20:45
Looking good Daran!! Cool ThumpUp
Better hurry up and finish it though mate or your Leopold/BR52 build is gonna start going backwards and times-a-tickin!! Blink Flapper BigGrin Wink
#105 Posted : 07 February 2015 21:55:58
Superb! Looks the biz Nem and some great weathering indeed Cool
Spencer
#106 Posted : 07 February 2015 22:56:08
I do like old CD cases, they are perfect supports and turntables, makes turrets so much easier to work on!!LOL BigGrin Although there are not many parts left to fit, there is still loads to do.BigGrin Next up is to use some Mr Surfacer and mould the weld seam where the turret halves join, then onto the cupola and hatches.BigGrin
#107 Posted : 08 February 2015 19:57:03
Well thats about it for now. The cupola and hatches are painted and fitted, and i have shaded some of the turret. There was a horrible gap around the cupola where it joins the turret, so this is now in the process of being filled. Once dry, sanded and painted I can carry on with the weathering and detailing.
#108 Posted : 09 February 2015 18:48:49
Some more progress made. Aircraft recognition stripes are done, coat of Klear next, then the decals. Another coat of Klear to seal them, and then on with the weathering!!!!
#109 Posted : 09 February 2015 20:05:04
Decals done with paint runs, and not evenly spaced from side to side to make it look like they were field applied.
#110 Posted : 10 February 2015 18:23:46
And so the weathering begins!BigGrin First off a light wash to blend the colours, then on with the chipping and scratches.
#111 Posted : 10 February 2015 23:59:13
Well thats this stage done, next up, highlight wear areas, pin washes, streaks, rust and mud!!!LOL BigGrin
michu
#112 Posted : 11 February 2015 00:35:24
This is amazing and inspiring work. I think I'm learning something with your every update, and can't wait to try some of the ideas myself.
Happy building :-)
#113 Posted : 11 February 2015 22:05:44
Well the turret has finally met the hull!!LOL BigGrin A few tweaks to do and then I am calling this done. The next pics will be in the Finished Gallery!BigGrin BigGrin
#114 Posted : 11 February 2015 22:59:04
Hi Nemesis,
Fantastic work on you tank, when I look at your paint work I feel that I'm learning from every picture, and I bet there are other guy's thinking the, same thank you for your support and posts.
Trev.
#115 Posted : 12 February 2015 00:54:21
tf64 wrote:
Hi Nemesis,
Trev.
Thank you for looking in and your kind words Trev, I am by no means an expert at the painting, I just go with the flow and it seems to work, if others have benefited from my advice and my builds, then I am pleased to have been of help to them.BigGrin BigGrin
6 Pages «<456
This page was generated in 0.140 seconds.
