Alan, Thanks for turning the pages, my worry about the main Victory buckets is that you need about 21 to go across the poop deck, now I reckon they must be about 3mm tapering down to about 2mm! or do you think just to make 21 that fit across but out of scale ? Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Steve, Thanks for looking and your comments, the problem I have is by habit I drift away and think up something new,and take ages to finish a build still more to follow soon. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
tf64 wrote:Jase, Well I had a another go at making those buckets I found it better with Lime a softer wood to turn, I was wondering if you have had the time to try your new Proxxon lathe yet and what type of wood you find best?
Trev Hi Trev, I have had a play with bits of scrap etc. I do find softer wood easer to work as you would expect, but also easier to make a mess off. Harder wood gives you some advantage if you are doing tight shapes like banister spindles etc. I am of the opinion, at the moment, that if you can get away with lime do so. As for your buckets I would shape them first then bore the centre after. Then I would paint and try and print the coat of arms glue on and varnish Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Jase thanks for the valued information I will give it a go and report back to you. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev  . Those buckets look great  , As Alan said they do look about the right size. Great work from a great modeller. Best regards. Mark
tf64 wrote:Jase thanks for the valued information I will give it a go and report back to you.
Regards Trev Dont recal if you had the detail packs for Victory or not, but i think i had a coat of arms pick in one of them that you could scale down and print. I will check tonight J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Mark, Thanks for looking and your comments Iv had a thought about those buckets and how to make them will post soon. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Jase, Not to sure what you mean about the Victory pack. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
tf64 wrote:Hi Jase, Not to sure what you mean about the Victory pack. Regards Trev http://forum.model-space...aspx?g=posts&t=1091
follow the link. if you had these i am sure there was a pic supplied. I am away at moment so cannot check the packs. J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
UPDATE: Victory Cross Section. Completing the Orlop planking. Today I completed the centre section of the Orlop decking,I found that I had to fit a false deck because when it came to cutting the planking it was so fragile it cracked, so the only way was to fit a false deck and stain the under side, the next job was to draw the outlines with a pencil using a new blade I marked over the pencil lines, I then drilled small holes around the markings and removed the wood with a knife and file. Next try the mast and elm tree pump castings for position and adjust for misalignment all seemed to be ok.  Centre Section To be planked but I had to make a false deck to allow me to make small cuts without splitting the wood.  This picture shows centre section with the wood removed.  This Shows the Elm-tree-pump castings in place.  Elm-tree- Castings and main mast in place. Next adding the frames to the pump well and painting white. Thank you for having a look at my work more soon. Regards to all, Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
That deck looks really nice. loving the build jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Very nice work Trev  the deck looks very neat. Steve
Great work Trev, coming along a treat.... Regards Alan
Hi thank you for your valued comments , Jase, Steve ,Alan Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trevor. Looking really superp. Look forward to seeing more of your cross section. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks Ian ,my thoughts are that to build a cross section before you attempt a main build ,will give you a good idea what's going on and have that hands on experience. Thanks again Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Like your thinking Trev and well done so far, looks great
We'll be introducing a 12-month video build of the Victory very shortly
Hi Trev, That`s coming on a treat. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Derek, Thanks for looking and your support. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE: VICTORY CROSS SECTION. 080315. Making Orlop Chests. In this short update I am showing a few pictures of the Orlop chests which are custom made to fit between the riders. Also I will be making a few seaman's chests in a variety of styles and sizes, on these I will add the brass strip to make the metal bands for the lids.      Thank you for looking Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Guest (7)
