162 Pages «<152153154155156>»
claret
#3061 Posted : 30 January 2015 10:17:35
absolutely stunning!
Not bad for a first build.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#3062 Posted : 30 January 2015 23:04:12
Claret
Thanks Claret, it really is great to hear from you again.... Cool Cool .. Hope your build is going well....
#3063 Posted : 31 January 2015 08:13:46
BigGrin Lovely job on the ratlines Alan looking bril ThumpUp Rgd Martyn
antswain
#3064 Posted : 31 January 2015 20:44:29
hi Alan
just spent the last hour looking at your build and still not seen it all! a credit to you beautiful job.
regards Ant
Current builds :
AL's HMS Surprise
Model Shipyards HM Cutter Mermaid
#3065 Posted : 31 January 2015 23:29:46
Thanks Martyn, am sure you'll have fun adding the ratlines to your rigging.....BigGrin BigGrin .. Thanks again.
#3066 Posted : 31 January 2015 23:31:34
antswain wrote:
hi Alan
regards Ant
Thank you Ant, thanks for taking the time to look in on my build, very much appreciated....Cool Cool .. Getting to the final stages now but still have some 16 issues to get through plus some additions of my own....Cool Cool .. Thanks again...
#3067 Posted : 01 February 2015 10:09:34
Hi Alan,
That rigging wow you have certainly have the knack to fit them (need a master class here)great job Alan.
Trev.
#3068 Posted : 01 February 2015 23:06:58
tf64 wrote:
Hi Alan,
Trev.
Thanks Trev, appreciate the compliment.... Cool Cool .. Only advice I can give with this is learn how to tie knots and make sure you have bucket loads of patience, patience being the prime ingredient....BigGrin BigGrin .. Thanks again..
#3069 Posted : 05 February 2015 23:14:48
Finally finished issue 118 tonight and although it doesn't very different I can say a lot of time consuming work has been done...Cool Cool . Started once again by adding some brass etch onto some already fitted ornamentation, fiddly but made easy with the pick up took described earlier... Added brass etch onto the other side of the prow.
Next task was to take the 6 cannons, gently filed away imperfections from the casting, gave them a coat of primer followed by 2 coats of gun metal black and finished off with a coat of satin varnish... Fitted the cannons centrally in the gun ports...Cool Cool
Last part of the build was the futtock shrouds on the upper sections of all the masts, shrouds on the upper main and foremasts before finally finished with another batch of knots on the ratlines....Cool Cool ..
Next up is working on the yards so till then, happy building all....Cool Cool
antswain
#3070 Posted : 14 February 2015 12:41:03
really looking superb Alan have you used a ropewalk for rigging on this model im really thinking about it for my Surprise. Looked at johncals and makes it look special - gotta get there first though! Laugh Laugh
Current builds :
AL's HMS Surprise
#3071 Posted : 14 February 2015 12:47:50
Thank you Ant, appreciate your kind comments...Cool Cool .. Haven't used a ropewalk for this one, just used the threads supplied but I have run the threads through some bees wax to reduce the furry effect...Cool Cool Agree with you, the work on johncals rigging looks fantastic, his efforts have certainly paid off....Cool Cool.. Right now my time is being spent making and dressing the yards, another time consuming process.... More soon I hope...Cool Cool
#3072 Posted : 19 February 2015 12:54:53
HI Alan sots looking superp. look forward to seeimg your progress.
Ian.Cool Cool BigGrin
#3073 Posted : 20 February 2015 22:56:28
Hi Alan, BigGrin
BRILLIANT WORK. Cool Cool Cool
When you`ve got nothing to do!!
LOL LOL LOL LOL LOL LOL LOL
How about a ships guide to the different parts.
May be useful to new ship builders and to be honest me as well. Blink
Can`t wait to see the end result of your Sots, not far off now for sure.
Awesome Build,
#3074 Posted : 20 February 2015 23:04:04
Thought I would give a small update on where I'm at and what I've been doing since my last update... Issue 119 started with painting and fitting of 6 cannons just as in the previous issue.. Then it was onto the main part of the issue, the making up of the yards. This also included the work that should have been done in issue 111, the cutting, tapering and staining of the yards. Didn't do this then as I had decided to replace the supplied dowel with walnut. Cut and tapered the walnut yards, gave them 2 coats of walnut stain finishing with a coat of clear matt varnish...Cool Cool
Moved onto fitting all the rigging blocks, these were all stained using medium oak stain as I wanted to get an old look rather than the clean pristine look as supplied. When done looked through the next issues and saw the yards didn't include any footropes so decided to make up my own...Cool Cool .. Tried different methods of making up the supports including blackened brass wire but didn't like the way it all looked. Experiments let to me settling with .25mm rigging thread creating a loop at the end by tying around a cocktail stick and each support was wrapped using .15mm thread. Brushed them down with watered down PVA to set everything in place... Finally secured the footropes through the loops. The footropes are now finished on the main mast and bowsprit, still have the main and mizzen to do before moving onto the next issue... A very long session with more to do but am sure I'll get there in the end..... Happy building all.....Cool Cool
#3075 Posted : 20 February 2015 23:06:49
Thanks Ian, always appreciate you taking the time to look in....Cool Cool
#3076 Posted : 20 February 2015 23:18:00
delboy271155 wrote:
Hi Alan, BigGrin
Awesome Build,
Thank you for the great comments Derek very much appreciated....Cool Cool .. There have been times where I wished I had nothing to do but thankfully they have been few and far between plus I have too many builds waiting in the wings preventing me from sitting doing nothing....BigGrin BigGrin BigGrin .. No chance of me being bored...BigGrin BigGrin
As for a ships guide to the different parts, thought I had this covered as I progressed through the diary but if you can give me an idea of what form the guide should take then I'll see what I can put together.... Always happy to oblige a fellow modeller... Cool Cool I know I have to bring the build index up to date but that is for another time I'm afraid....Cool Cool
Thanks again Derek,
#3077 Posted : 20 February 2015 23:20:48
BigGrin Very nice work Alan and well done with the extra addons it all makes a great build better, keep the pic's commingCool
#3078 Posted : 20 February 2015 23:37:15
Thanks Andy, appreciated as always....Cool Cool .. Thought the omission of footropes was quite a major feature for these ships, the spars to me looked naked without them.... Cool Cool .. Strong possibility I will be adding additional rigging to that instructed so will see how we get on.... Cool Cool .. Thanks again..
#3079 Posted : 20 February 2015 23:46:58
#3080 Posted : 20 February 2015 23:56:54
stevie_o wrote:
Brilliant work Alan, a stunning build BigGrin It will be a historic moment indeed when this build concludes. I'm sure you will replace it with something equally as good thoughLaugh
Thanks for the fab comments Stevie, still some 16 issues to get through yet plus the few extras I have in mind so will be a while yet before it's done....Cool Cool .. Have plenty to choose from for my next build and the hardest part is choosing which one, that'll be another challenge no doubt....Cool Cool .. The extras I've done here is a very time consuming thing to do especially with the way I've done it but think it makes the effort all worth while....Cool Cool .. Thanks again..
This page was generated in 0.395 seconds.
