Bowsprit masts and caps Options
sgrich
#1 Posted : 29 January 2015 23:05:14
Hi every one ,
I'm at the stage of assembling the bowsprit at issue 113 and have hit a snag as follows:
The mast part 1b has been made to the dimensions 4mm at one end and 3mm at the top
As per the drawing supplied .
The parts 173 that is the caps that fit have a 4 mm hole which is way too big to assemble it
Has anyone else had this problem or have I done something wrong
Regards sgrich
#2 Posted : 30 January 2015 00:59:42
sgrich wrote:
Hi every one ,
Regards sgrich
Hi SG, don't think you have done anything wrong here as I found the same problem with this part and solved it by using slivers of Sapele strips in the cap hole to give me a snug fit.... Look at this page of my build and you will see I referred to the problem here...
http://forum.model-space...ts&t=5013&p=152
Hope this helps..
sgrich
#3 Posted : 30 January 2015 10:24:08
Thanks Alan for your help
I'm gonna make some plugs and after glueing them in will re drill the holes , marvellous what a nights kip can do
Cheers
Sgrich
#4 Posted : 30 January 2015 22:17:56
Cheers
Sgrich
Happy I was able to help SG, good luck with the rest of your build.... Cool Cool
