7 Pages 123>»
Titanic 1:250 strip down & rebuild Options
Titanic5972
#1 Posted : 26 January 2015 06:25:25
Hi All
i have just purchased a part way built Hachette 1:250 Titanic. I am planning on stripping it down and starting again as the keel is not very straight and id like to make it true. I have managed to cut the decks off, however the keel and frames are very securely PVA'd on. I have heard of steaming these parts to loosen the glue but have never attempted it before. Can anyone give me some hints and tips as to how to go about it?
Thanks
On the Go
RMS Titanic 1/250 (third time)
Completed
RMS Titanic 1/250 (twice), DK Bismarck 1/200, RMS Queen Mary 2 1/400, HMS Hood 1/200
swordfish fairey
#2 Posted : 26 January 2015 11:00:26
Hi '5972, I used to know a "Chippy" in the R.N. who used vinegar after he soaked the joints (either steamed or just water)......It always seemed to work well for him and may be worth a try.................Tony
spikee
#3 Posted : 26 January 2015 12:23:40
As just mentioned above,Ive always found if you just pour boiling water onto the joint and let it soak into the joint for a minute or two,the joint just pulls apart easily.
Jon
#4 Posted : 26 January 2015 13:26:30
Soak the joint in hot water the PVA should become malleable fairly quick. I have wrapped a hot water soaked cloth around a joint before now and that worked ok.
Just be mindful that hot water is also used for bending the ply so go easy
Good luck
#5 Posted : 26 January 2015 13:42:35
Personally I wouldn't use boiling water, you need to save the frames and keel and you will risk warping the parts by fast heating and cooling. Warm to hot water should do the trickBigGrin
Titanic5972
#6 Posted : 28 January 2015 20:31:16
So having decided not to completely strip it down, I have added the 3 main side and bottom hull pieces. This has straightened out the keel somewhat, and the planking will further do this, I am ordering the etched Minibrass bulkhead replacements as I believe they will look much finer than the cardboard decals supplied. Once these arrive the build can really get underway. Until then, I will concentrate on getting the Hull planked and painted so the major part is done. Pics will be posted as i progress.
On the Go
Completed
#7 Posted : 29 January 2015 12:51:41
Look Forward to seeing some pictures of your build IanBigGrin
Titanic5972
#8 Posted : 01 February 2015 08:38:41
Hi all. Here is the first updates of my rebuild. The hull planking first layer has been completed. Next will be filling and sanding to give her a nice smooth finish before the second layer of planking goes on. More updates soon.
Titanic (1).JPG (913kb) downloaded 112 time(s).
Titanic (2).JPG (916kb) downloaded 63 time(s).
Titanic (3).JPG (918kb) downloaded 56 time(s).
Titanic (4).JPG (928kb) downloaded 53 time(s).
Titanic (5).JPG (913kb) downloaded 50 time(s).
Titanic (6).JPG (926kb) downloaded 75 time(s).
On the Go
Completed
Titanic5972
#9 Posted : 01 February 2015 10:23:44
And if someone could explain how to get my photos to show up here rather than as download links It would be greatly appreciated.
On the Go
Completed
#10 Posted : 01 February 2015 13:51:54
Hello,
I believe you need to resize them to 640 x 480? Anything bigger and they will be shown as download links.
Kev BigGrin
Titanic5972
#11 Posted : 02 February 2015 09:19:31
Ok cheers. I'll give that a go next time
On the Go
Completed
Titanic5972
#12 Posted : 02 February 2015 13:10:58
Hi all
trying again with the pictures. These are the same as the ones previously uploaded but ive resized them so hopefully that works.
Titanic5972 attached the following image(s):
On the Go
Completed
#13 Posted : 02 February 2015 13:30:23
Nice picks I will be following with interest.
A liner is on my wants listCool
Titanic5972
#14 Posted : 03 February 2015 00:21:04
I have now done the first layer of filler on the hull. It looks Horrendous at the moment but once it is sanded down and has its first coat of primer, any holes will be redone and it will get there.
On the Go
Completed
Titanic5972
#15 Posted : 03 February 2015 05:55:32
While the Hull filler is drying off, the funnels are underway. Just need final filling, sanding, & painting.
On the Go
Completed
Titanic5972
#16 Posted : 05 February 2015 23:37:59
So I will be doing a few modifications to the funnel piping on Funnel 3. I've added a photo that shows the correct piping layout so I will be adding this to my funnel shortly. Picture belongs to Art Braunschweiger I believe.
On the Go
Completed
Titanic5972
#17 Posted : 06 February 2015 10:41:27
Here is the latest update. The port side of the hull has now had its second layer of plating applied and i just need to drill the portholes on this side. Starboard side will begin shortly.
On the Go
Completed
#18 Posted : 07 February 2015 09:12:29
Looking great, some really nice work done her.... Cool Cool .. Nicely done...Cool Cool
Titanic5972
#19 Posted : 07 February 2015 12:42:20
Thanks Alan
Having built 2 of these before, I know all the pitfalls and what needs to be modified now. I'm awaiting the arrival of the photo etch set before I can continue the superstructure so now seems the perfect time to get the hull completed, painted and varnished.
On the Go
Completed
Titanic5972
#20 Posted : 12 February 2015 04:53:21
So i have ordered my first etched parts for the Titanic. The forward C deck parts, aft C deck parts, and the Bow & Stern profile pieces.
On the Go
Completed
7 Pages 123>»
This page was generated in 0.313 seconds.
