4 Pages 123>»
starship scratch build new build entry Options
godan61
#1 Posted : 23 January 2015 21:46:16
Competition Winner of Model Builds: Competition Winner of Model BuildsBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Ok would help if I post in the right area, after working with wood to scratch build a japanese galley this build will be MDF, Plasticard to build a starship with no kit parts. I was looking at the Sulaco from aliens which was a trio transport and thought what would a battlecruiser look like so here goe, basic framework done in MDF
godan61 attached the following image(s):
#2 Posted : 24 January 2015 09:16:13
BigGrin Looks interesting, will be following your progressCool
#3 Posted : 24 January 2015 09:27:55
It's always great to see something different and this should be very interesting to follow.... Good luck with the build....
#4 Posted : 24 January 2015 12:29:51
#5 Posted : 24 January 2015 13:25:31
I take this is a what if rather than an actual ship that was in the film?
Either way its a very interesting project and I will really enjoy following this.
#6 Posted : 24 January 2015 13:29:48
A battle cruiser based on the Sulaco, this will be interesting to watch! Big Alien fan!!BigGrin BigGrin
godan61
#7 Posted : 24 January 2015 14:04:43
Yes its a what if Dave and one thats getting quite an obsession, perhaps its the working in different mediums and the fact that I can let the imagination run riot.
Will post again later as spent a bit of time today on it (not sure the wifes so happy)
godan61
#8 Posted : 24 January 2015 20:28:06
So a long day in the workshop today as we all know January is a long month, what I wanted to achieve was the rear super structure and the dorsal section and hopefully some plasticard.
godan61
#9 Posted : 24 January 2015 20:29:55
so the second part with work on the rear
#10 Posted : 24 January 2015 22:53:25
Congrat's on your first medal and good luck with the build Cool
godan61
#11 Posted : 25 January 2015 19:58:08
Ok one of the days it just all goes right and have 2 new friends called super glue and liquid poly, using these allow you to do a lot more work than working with wood and glue.
One slight concern is I have become a little obsessed with this build so think just a little bit of work on the engine bell during the week and see if I can get the back end on next weekend, one thing thats just dawned on me is that this is going to end up nearly 3' long oops.
This is probably it until this time next week but have to say the plasticard gives a nice surface to act as a base for the detail.
#12 Posted : 26 January 2015 19:18:41
Lovely design concept, I can see the Sulacco elements appearing, especially around the nose!
Looking forward to seeing this one come together!Cool
Robin
godan61
#13 Posted : 01 February 2015 18:04:09
Ok so this week and weekend has been to concentrate on building the engine and reactor section on which the detail will go.
I have decided that there will be no model parts at all in this build so with that in mind I used inch and a half waste pipe covers which were perfect, I then rolled a sheet of plasticard to make the engine and cut the flutes out.
Coretex along with plasticard panels form the raised sections, I also added parts of the side superstructure with mdc and cortex.
Have a couple days off this week so hoping to block in the superstructure with plasticard so I have a base to work from.
#14 Posted : 01 February 2015 20:48:09
Looks fantastic!! I take my hat off to you!!BigGrin BigGrin
godan61
#15 Posted : 01 February 2015 22:05:33
Thanks it really is a voyage of the unknown working with 2 mediums I have never put together before but the fun bit is not having a plan just a concept. Let your mind just run riot.
godan61
#16 Posted : 08 February 2015 20:33:04
Ok so had 5 straight days off work so cracked on a bit, have blocked in all the superstructure. First rule I have learnt cut 2 one left one right, also do each piece alternate so you keep it balanced.
The engine bell needs cleaning up and a bit of realignment but will do that in the next phase so all the body is on one line.
also used thin plastruct section to put on some of the forward detail and either side of the central structure channel, this channel will house the loading bays and other detail.
The top shot shows the shape lovely just what I was going for, just a little cleaning up on the nose.
Think the next posts will start to get farther apart as there is quiet a bit of detail to go on including armoured panes, engine section detail and weaponry.
Remember no model parts to be used thats the challenge.
godan61
#17 Posted : 08 February 2015 20:34:58
Ok so here are the pictures that show where we are up to now.
#18 Posted : 08 February 2015 20:46:35
Looks fantastic, excellent work!!BigGrin BigGrin
dandare
#19 Posted : 09 February 2015 08:49:09
looking great
good to see somthing unique being built from scratch
dan
godan61
#20 Posted : 14 February 2015 19:54:52
Ok so just a little bit of work this week, thought Id reconnect the lights just to see how they look and make sure they work before I start detailing.
4 Pages 123>»
This page was generated in 0.402 seconds.
