planking Options
turboman
#1 Posted : 29 August 2010 16:11:46
Rank: Beginner Level 3
hi all do the ribs have to be sanded back level with the floor on the canon decksi have a few seem to big
cheers turboman
CMB
#2 Posted : 29 August 2010 17:44:06
Hi turboman,
I have had to sand back several of the ribs to line up with the deck boards and also have had to add between 1mm & 2mm to others as they were a little on the narrow side.
The best way is to test with a plank at the fairing stage and any unevenness shows up either as a slight bulge or depression. It is worth checking the whole length of the ribs from the false keel through to the upper deck at this stage, the top section of the ribs can be checked later as the build progresses.
Hope this helps.
Happy building
CMB
Boaz
#3 Posted : 30 August 2010 02:37:10
I have the same problem. A lot of my ribs are set back from the edge of the deck so does tht meen I will have to pack them out? I almost started to sand the deck back to the ribs Blink
Bob
Jack Sparrow
#4 Posted : 30 August 2010 02:43:38
Rib 15 is the major headache, so I am going to build up the lower ribs before I start fairing any of the hull. Hopefully then, there wont be as much to sand back, but we will see!!!!BigGrin
jonny7england
#5 Posted : 30 August 2010 09:51:00
What will you be doing about the top of rib 15? Like the idea of building up the lower ribs, I think that it may be a necessity, got no problem with all the extra work I have to put into it, that's what modelling is all about, just that I don't like how deformed rib 15 is!! Good luck on your build, keep us posted on how you get around the problem mate...Confused
Jack Sparrow
#6 Posted : 30 August 2010 11:24:11
I have been having a good look this morning at the state of the ribsBlink , and I have some higher on the port side than on the starboard side and vice verseCrying . The hull is 100% square and true, Its just how it is!! I suppose if I had fitted the ribs the other way round the outcome would have been different!!Blink So here is my plan of action, it may not be the best solution, but it worked on my Black Pearl and I am happy with that.BigGrin
All of the ribs that are lower than the deck will be built up with 1x3mm planking until they are slightly proud of the deck. I have measured and re measured the decks and I am happy that they are equal and square.BigGrin Now for the top of rib 15!!! If you look down the side of all of the rib tops, none of them are level, some are out and some are in.Cursing Its just that 15 is worse than the others!!! I am going to wait until I have all the decks before I look into that one, but its gonna need work to get them all the same. They were not cut well at all!!!!Angry I will fit all the decks and then do the same as the bottom, build up and sand back. This is how I am going to sort this, It worked once so why not again!!!!BigGrin BigGrin
jonny7england
#7 Posted : 30 August 2010 12:17:25
Blimey!!Huh Blink Good luck on that Confused Haven'ty worked out how I am going to tackle mine as yet..Blink Confused .keep me posted on how you get on, sounds like a heck of a lot of work you've got on there mate, but hey, that's modelling..BigGrin
