trouble resizing pics Options
benny
#1 Posted : 28 August 2010 10:16:36
hi ..i am currently resizing my pictures in my build diary i am doing the same thing everytime when editing the photos but some are resizing nicely when i repost,i am using photobucket they are resizing fine on there but when i recopy the code then paste it on my diary some just wont have none of itConfused i am just about to drop kick my pc over the fence....does anyone know whats going on..thanks
cheers benny
Dontshootme
#2 Posted : 28 August 2010 16:21:50
I had that problem a couple of weeks ago,I even resized them in photoshop but still got same result.
I think the way I cured it was to delete the pictures completely from photobucket,delete all the links you have put up & start again.
Try using the microsoft picture viewer to resize & then upload to PB,or any other picture editing software.
If you don't have your own software try http://www.getpaint.net/ which is a free picture editor from microsoft originally designed to replace Paint.
Good luck,hope this helps.
benny
#3 Posted : 28 August 2010 17:02:10
cheers rob what a nightmare i have been on this for 5 hours..if you look at my diary i have done most of them now but still aving trouble with 4 pics...if i dont succeed with them i will try your idea..thanks
cheers benny
jonny7england
#4 Posted : 28 August 2010 17:48:57
Benny, just a point of interest, what code was you using on photobucket (HMTL or IMG code) to copy and paste onto this forum, as I was thinking of starting a build diary but somehow, I'm having problems transferring pictures from photobucket to this forum, thanks, much obliged...
Confused
benny
#5 Posted : 28 August 2010 17:53:30
hi jonny its the img the last one out of the 4 drop downs
cheers benny
jonny7england
#6 Posted : 28 August 2010 18:00:41
Thanks mate, I'll give it a go, and as for re-sizing, that's another problem for another day for me to sort out....ThumpUp
Son of Bulwark
#7 Posted : 28 August 2010 20:26:40
Hi benny! BigGrin
On the forum the best size for your picture is 700 pixels wide so resize you picture 700 pixels wide before uploading to photobucket and use the second code down on the share links, that's the Direct Link left click on the link then right click and select copy, before you paste it into your post. If you don't resize the pictures down to 700 pixel it can be resized be the forums program to make the file smaller this is why your pictures can look poor on the forum.
ThumpUp Darron
This page was generated in 0.120 seconds.
