2 Pages <12
Starting Options
Bdizzle84
#21 Posted : 07 January 2015 11:51:39
Got mine running for 10 seconds...after I'd taken the fuel out Laugh Tricky thing to get going. Need a new pull start as the old one failed Mad
Building: RB7 Nitro / Senna MP4/4 Finished: McLaren MP4/23
Brad.
#22 Posted : 07 January 2015 12:14:44
You'll find that once the engine is run-in, it will settle down.
Try not to avoid pulling as hard as you might do a lawnmower or chainsaw etc and try not to overpull.
Carl71
#23 Posted : 07 January 2015 17:18:21
Not sure why we upgraded to a new starter handle? After replacing as described and 3 attempts at starting it failed each time. I swapped back to the original starter handle and have had over 30 starts with no failure.Confused
#24 Posted : 07 January 2015 17:39:17
Likely that Kyosho thought a larger version was better suited for grip
Bdizzle84
#25 Posted : 08 January 2015 14:17:07
That's what I thought. To be fair it's probably my knot wasn't good/big enough. When the new one lands I will be leaving as is as it seems fine for my hands.
Brad.
2 Pages <12
This page was generated in 0.124 seconds.
