plank conrwall models Options
johny5
#1 Posted : 27 August 2010 15:12:27
Rank: Amateur level 2
dose any one no wot size planks i need a brok a lot iv been on cornwall models web site but not to sure wotto order/for the hull planking thanks
ArtfulBodger
#2 Posted : 08 September 2010 10:15:50
There seems to be remarkable lack of reply to this post. I too would like the shipwrights views on this. My thinking for deck planking is 0.2 x 3 mm mahogony but I'm not sure; should it be 0.2 x 2 mm?
Any ideas on dimension, wood type, thickness etc. would be gratefully received both for deck planking and hull planking.
Cornwall models have a host of options + any other wood you might suggest. Because of the freight charges it seems prudent to do a single order so estimated quantity would be helpful as well.
I now realise why it's so uiet in here, because there is another stream elsewhere. However, the questions remain.
Others have suggested 0.5 x 3mm walnut for the decking and 1mm x 3mm Tang something for the hull planking. There was also a suggestion of 0.5 planking but I'm not sure if this is to thin for the hull.
ArtfulBodger
Previous Build:
HMS. Bounty
#3 Posted : 08 September 2010 10:39:34
Hi Artful and Johny,
The Deck planks for being within scale need to be 3mm wide. The thickness is down to you, I have used 1mm thick on mine.But 0.5mm is ok aswell( I think the official build will be 0.5 mm thick)
The planks for the hull on the other hand are normally 2mm thick and 5mm wide. This is pretty much standard on all kits.*EDIT-(Single Planked ones)* The colour is your choice though. The planks that are being fitted at the moment by Tomick are basswood/limewood.
Hope that helps
Chris..
ArtfulBodger
#4 Posted : 08 September 2010 12:41:56
Thanks Magpie that is very helpful although I've no idea what the link to Nuneaton United Football Club NUFC or are there some football clubs up your way? Haha.
ArtfulBodger
Previous Build:
HMS. Bounty
This page was generated in 0.105 seconds.
