Lower Gun Deck Cannons Options
riff-raff
#1 Posted : 27 August 2010 14:28:23
Hi All
I am now ready to start thinking about placing the 3 cannons built in to the lower gun deck (open view version) does anyone know how far the cannons protude over the lower gun deck to be in line with the dummy cannons used later on the same deck?
I don't want to fix and rig them only to find that they are in the wrong position.
Thanks
Built:
andylangtree
#2 Posted : 27 August 2010 14:38:39
Not sure how far they would stick out but the 3 cannons supplied upto now are 12 pounders (i think) and the lower gun deck would have had 32 pounders which i believe maybe a different size, i could be wrong about this. Not even sure we will get different size cannons.
#3 Posted : 27 August 2010 15:08:59
the lower gun deck should have different cannons,the cut out part will have a removable floor and will be fixed outside of the deck,and a whole diarama will be created, and the whole lot can be slid into the lower deck, so you rig them cannons outside the victory(I think)
riff-raff
#4 Posted : 27 August 2010 15:53:43
MMMmmmmmm Thanks for the info although the cut-out I am creating is going to be different from the cut-out they recommend.
But I do take you point on the cannons - we'll have to wait and see what's supplied.
Built:
Mac
#5 Posted : 28 August 2010 16:31:45
Hi Riff-Raff
Andy and Karl are correct, its the larger 32 pounders on the lower gun deck. It will be interesting to see what will be supplied after the recent 12 pounder mixup! BigGrin
Pam's shipyard is closed for now no more room!
This page was generated in 0.191 seconds.
