2 Pages <12
Paul Morley Options
Paul Morley
#21 Posted : 30 December 2014 14:32:14
Rank: Beginner Level 3
After reading and taking a LOT of advice I have decided as a first timer at wooden boats... Infills were the order of the day... This I started with a mixture of excitement and apprehension ... I also preempted the fact I have heavy fingers and reenforced the 2nd rib from the aft castle, a number of builds have had misfortune in this area and Knowing I am prone to breaking things ... Lol
Paul Morley attached the following image(s):
Novice. First build SoTS
Paul Morley
#22 Posted : 30 December 2014 14:35:25
Now for the infills ...
Paul Morley
#23 Posted : 30 December 2014 14:37:14
I also decided to run a little infill along the length on the false keel for additional support.. Taking ALL the advice of various build diaries ... Making sure I don't relearn the lessons of the other master builders....
Paul Morley
#24 Posted : 30 December 2014 14:41:11
Moving to the shaping ... I found using a mouse sander with a 60 grit... Very very helpful in getting the shaping down to rib level ... Before finishing with a second cut file, down to the required rib bevels..
Paul Morley
#25 Posted : 30 December 2014 14:42:31
Final end product... Very happy ... And killed what ever apprehension I had... Ready for the stern now ...
Paul Morley
#26 Posted : 30 December 2014 14:48:50
Stern was not as bad as I expected .... Here I used a mouse sander and a 2 inch PVC pipe sanding block to get the angels... I found the round improvised sanding block a lot easier to use than the 2nd cut file ... Felt I had more control ...
Paul Morley
#27 Posted : 30 December 2014 14:51:45
Finished the stern ... Very glad ... And excited to start the planking ...
Paul Morley
#28 Posted : 30 December 2014 15:02:19
Paul Morley wrote:
I also took the hint and guidance to reenforce the hidden gun walls.. With balsa... And added extra blocks to support the second deck ... Very sturdy construction.. Feel very happy with the out come
Paul Morley
#29 Posted : 30 December 2014 16:42:59
Been playing with stains, today, for the skiff. Very disappointed in the results I got.. So I will go back to the drawing board and do experimenting ... Tried a product called Sherwood stained wood sealer ... Not what I was expecting
Paul Morley
#30 Posted : 30 December 2014 19:51:11
Ok .. Finally got onto planking the stern tonight.... Had a hic up or two, found I cut some of the initial planks to short.... Quickly fixed that ... Now it's not looking to bad ..
Btw merry Xmas all.
#31 Posted : 30 December 2014 22:38:54
Paul
Looking really good.
Hope the rest of your build goes well.
#32 Posted : 30 December 2014 22:49:36
Very nice tidy work Paul, planking looks spot on....Cool Cool
2 Pages <12
This page was generated in 0.459 seconds.
