Official Harley-Davidson Fat Boy Build Diary Stages 21-23 Options
#1 Posted : 23 December 2014 11:28:42
Pack 6 contains stages 21-23.
Stage 21 contains a screw driver and the battery case.
For this stage you will need the fuel tank caps from stage 16, the fuel tank assembled in stage 19, the 'T' type screws and instrument panel from stage 20 .
Take the instrument panel and line it up with the two holes in the top of the tank, hold in place and turn over and fix in position with the two 'T' type screws. Finally take the filler caps and fix them temporarily into the top of the tank.
Store the assembled and unused parts safely in a bag labeled with the stage number for future use.
#2 Posted : 23 December 2014 12:04:26
Stage 22 contains the right swing arm and screws.
For this stage you will need the right side engine crank case from stage 7, a 'F' type screw from stage 10 and the ventilation pipe from stage 12.
Take the crankcase and line up the ventilation pipe with the two holes you will know its in the correct position when the pipe fits in the crankcase slot. Then take a 'F' type screw and fix the pipe in position.
#3 Posted : 23 December 2014 13:00:39
Stage 23 contains parts for the front wheel hub and screws.
The brake disc from stage 4 will also be needed for this stage.
Take the brake disc and the brake disc mount and line up the square stud with the square hole and push gently home. Next take the inner and outer wheel hub parts and again line up the square stud with the square hole and push gently together.
Store the assembled and unused parts in a bag labeled with the stage number for future use.
This page was generated in 0.121 seconds.
