bearing in issue 39 Options
AF78
#1 Posted : 22 December 2014 13:27:02
Has any 1 else had problems with the diff on the RB7 ?m im building parts from issue 39, number 2 in the guide. says to put the ball bearing onto the cap as far as it will go, the shaft on the cap is 10mm and the ininside of the bearing is only 8mm. Wondering if any1 else has had this problem and how they got round it.
Also wandering who to contact about the problem, Thanks
#2 Posted : 22 December 2014 14:46:55
Hi AF78
There hasn't been any issues with bearings connected to your differential problem as such but there was a difference in size of bearing for the rear hub that some members encountered with the bearing being smaller than the hub allowing movement rather than a shrug fit. This was resolved my the affected members contacting customer services, these details can be found on the inside page of your magazine that you receive with your parts.
Any other questions then please feel free to ask.
Spencer
This page was generated in 0.142 seconds.
