Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
well here goes..i thought i would start off with a few pics of the finished pieces we first received, a few stages are missing but thats down to my nikon coolpix, seems to struggle with close up shots as you will see with a few pictures i will put on here.. (any advice is welcome but i think its the camera) so first is the anchor i thought i would wear out the edges a bit to give it a worn look,  cheers benny
the cannons..3 times i built these to get a standard i thought was acceptable..the ends are red ochra and 2 coats of satin clear   cheers benny
 cheers benny
the launch..what a pain in the arse..i stripped it down 4 times..now i have something which is the level of my capabilities  cheers benny
 Rank: Pro Groups: Registered
Joined: 08/05/2010 Posts: 236 Points: 808 Location: Manchester
see if your camera has a 'macro' setting. (zoom is disabled) well it is on my camera. Also plenty of light, natural light is prefered failing that artificial will do. your build is coming on nicely. Im not brave enough to carry on lol. I need some rum to continue, maybe somebody could spare some of that smuggled brandy! i dont know what weapons will be used in ww3 but ww4 will be sticks and stones.
Hi benny!  I see you've start your diary good for you!, the worn look of your anchor makes it look like it been used alot. The sea bed isn't just sand looks like the stock hit a number of rocks, spot on!  As for your problem with focusing on a close up shot use a small tripod and use the timer function, this will reduce any shaking also use the zoom to max and move a little further back. It's what I have to do as my camera is worse than yours. Keep up the good work.  Darron
3 coats of satin varnish  cheers benny
the launch before i cleaned it up.. controlling the glue must come with practice  cheers benny
the sail i painted with a mixture of walnut stain and wood glue to give a worn/aged affect  cheers benny
 cheers benny
son of bulwark and piot thanks for your tips will try them out and thanks for your comments cheers benny
piot007 wrote:see if your camera has a 'macro' setting. (zoom is disabled) well it is on my camera. Also plenty of light, natural light is prefered failing that artificial will do. your build is coming on nicely. Im not brave enough to carry on lol. I need some rum to continue, maybe somebody could spare some of that smuggled brandy! if we ever have a forum/build meet up i will buy you a large one cheers benny
 cheers benny
now start of the jig and the initial build not in the class of bulwarks jig and i must say that was impressive but the simple oak shelf and metal right angle worked for me  cheers benny
 cheers benny
now we have the decks its time to install the ribs..which have been on press, well, it seems for months..  cheers benny
 cheers benny
time to get the decks in..the pin pusher from deag caused no problems at all  cheers benny
 cheers benny
now the bow formers  cheers benny
Guest (12)
