coming along nicely. Some good pics you got there Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Making great progress DaDokta, she looks great and your work looks very neat and tidy - well done.
Kev
looking good dadokta. did you have any issues gluing the cockpit in. mine seems to have stuck now but didn't first time and when it came off first time it looked as though the glue hadn't even made contact where the back of the cockpit meets the back of the headplate? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Hi Steve, yes i actually had problems glueing the cockpit as well. Had to try it twice. Even after the second time the cockpit sat about 0,2mm too far to the rear - which at first i thought wouldn`t be an issue. But it was an issue when adding the ground plate, which - as it is screwed onto the cockpit - also sat 0,2mm too far to the rear. With the cockpit already fixed i had to take away those 0,2mm at the end of the ground plate, to make it fit. Without knowing it, one can`t see any difference - so i`m content with the result of the little surgery. Greetings, DaDokta Greetings, Walter
Well done. Them hoses look like they've come out quite good. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Hi guys, i tried to enhance some parts of my build a little bit:
First i tried to add some depth to the gearbox, using the dry-brush-technique for the first time in my life. Also painted some of the bolts:Then i added the sponsor decals to the monocoque and painted the bolts
[size=8]Also some touches to the side boxes:DaDokta attached the following image(s): Greetings, Walter
Joined: 02/03/2015 Posts: 84 Points: 245 Location: England
Looks great mate, the bolts really set it off! Building the MP4/4!
 Rank: Pro  Groups: Registered
Joined: 24/09/2013 Posts: 180 Points: 550 Location: East Sussex
Fantastic! Love the heat staining!! I will be keeping an eye on this build for sure!!
Joined: 27/06/2014 Posts: 393 Points: 1,104 Location: st austell
Very nice Walter. Ian Facebook-model maker
Thanks guys!
Looking Forward to the next shipment.
WalterGreetings, Walter
Hi Walter, Great job with this build and great to follow. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 Very nice work there Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Fabulous work DD and one of the better MP4/4 builds on here inmho, I love the heat-stained radiator tops!!
Love all the little extras you are adding and the detail painting is great. If I may suggest though - don't overdo the wear and tear and weathering on your model as these cars were nearly always kept in tip-top condition and cleanliness was usually the name of the game? I think subtle weathering is all it needs, anything more would just look wrong?
Great work nonetheless DD and well done, I'm looking forward to seeing more from you!!
Kev
Coming along nicely. That's the stage I'm at too. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Very nice work, I really like the look of those braided hoses
Very nice, those little extras make a big difference. I can't wait to get stuck into my build. Malc.
 Great work Walter, looks the bizz Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks guys for your nice comments!Greetings, Walter
Good morning, here are some pics of this months shipment. Again i did a little touch-up with Aluminium paint and a some dry-brushing: DaDokta attached the following image(s): Greetings, Walter
Looking good Walter. I'm on this pack at the moment but struggling to find time to finish it. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
