OK, on to the next one  I know I promised the Red Arrows Hawk next but this one wont take long I have an idea for this, aircraft ditched into shallow water on a white sand beach. I will set the dio in a clear perspex container around 350mm square, possibly turquoise tinted water or perspex, the container then half filled with polymer resin. The aircraft will have extensive damage from the water ditching rather than the cause of the forced landing as you will see below. I also want it to look like the pilot left the aircraft after so perhaps some straps hanging outside the open cockpit. The kit itself is old and low on detail and parts so would not be up to a stand alone display piece, hence the damaged dio. There are no etch sets available so it's an almost "box" build, but I probably wont be able to resist a few additions As you can see below I have made a start on the damage already, some beer can tin to simulate the ripped metal and I have put in the 3 main spars twisted off too. I filled and sanded the ridge of the tin and am hoping the join is flat enough. None of this is meant to represent the real wing internals, it's just an effect so not accurate in any way. The longer wing with missing control surface is going to be partially sand covered around the tip. The dio is not going to be aged, as Im hoping to replicate a recent ditching but there will obviously be some weathering. I will possibly cut out the flaps and rudder to reposition them. BTW, the engine is only 5 pieces, and a nice change from numerous parts that cant be seen - said this would be a quickie didnt I? Steve stevie_o attached the following image(s):
Ooooo this is going to be fun to watch! Super start and love the damaged wings!!
That looks amazing Stevie, definitely going to be watching your progress on this one!!
Love the way you've done the damaged wing tips, very impressed!!
Kev
This is going to be different and fun to see.... Will be watching to see how it all turns out.... Great start Stevie, ripped wing panels look fab.... Regards Alan
Thanks guys, yep, should be fun - nothing too serious in this one, Im keeping it simple...ish Sincere apologies to anyone who knows anything about this aircraft - I thought the inside cockpit sides were too bare (well could they get any more bare)? I have had a dip into my spare etch box and stuck a few bits in randomly just to break it up a bit I have cut out the rudder and elevators as these were molded in and will re-position in a moved, poss damaged pose. Steve stevie_o attached the following image(s):
Great start Steve and love how you portrayed the damage to the wings
Hi Steve, Great imagination showing through here and a FAB start. Some serious bending of the prop would be in order too. I have some pics I can PM or email you if required, as I cant publish them direct onto the forum, copyright and all that you know. Looking forward to your progress with this one. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thanks for looking, Yep Del, get the pics emailed if you like and I will certainly be bending the prop blades too Cheers Steve
Lovely work Stevie, I would never have thought that beer can metal was so malleable to achieve that 'rent metal' look, you've done a wonderful job on that! (And you seem to have a never ending supply of the cans too!!) Looking forward to this one coming together M8! Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Thankyou Robin, certainly do keep plenty of beer cans handy  They are perfect really, they can be pressed into shape to form a skin but thick enough to hold their position. You can twist and tear it with pliers too. Primed the wings, re-sanded, filled, primed and sanded again and then it looked not too bad  Still have to sort some of panel lines out though. Steve stevie_o attached the following image(s):
Looking better with every post Steve. I think this is going to be such a cool build when it's finished and can't wait to see the ditched plane in its' full beachside diorama!!
Kev
Joined: 15/07/2014 Posts: 204 Points: 578 Location: Alabama, USA
Those wings look really cool! Looking forward to seeing more Building - DeAgostini HMS Victory, McLaren MP4-23, Suzuki GSX1300R Hayabusa, Harley Davidson Fat Boy, Lamborghini Countach
The end result should be real good
Loving the idea of this duo. your wing damage looks really nice Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Steve, This is  . Those damaged wing edges have blended in really well. A credit to your insight and skill. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thanks for looking in guys A couple more pics of various bits, put a buckle in the one wing and the tail also, this will look way better with some heavy chipping and paint cracking in the bent areas. Cockpit done also, pretty standard, nothing new added as very little will be seen, same with the engine really so this was just a steel and aluminium base with a black wash and that should do with the amount that is seen. Going to leave the filler overnight before sanding. Will make a start on the prop now Steve stevie_o attached the following image(s):
Looking really Amazing detail Building - DeAgostini HMS Victory, McLaren MP4-23, Suzuki GSX1300R Hayabusa, Harley Davidson Fat Boy, Lamborghini Countach
Hi Stevie, not very often we get to see someone trying to put a wreck together, normally its beautiful pristine builds.....  .. Think you are doing a great job of this one, some very interesting and informative techniques being shown... very nicely done and look forward to seeing more.... Regards Alan
Thanks Alan, Ponty Did some work on the cowl, cowl flaps and prop. Sprayed a base of Aluminium with a bit of chipping. The prop needed to look not only general weathered but also some damage from the impact with water / sand, fairly happy with it though but will prob get another filter type wash and perhaps some salt streaking when the rest is ready for weathering. Steve stevie_o attached the following image(s):
HI Steve, Looking good and can`t wait to se the final scene with all the weathering etc. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
