21 Pages «<678910>»
John Passmore Options
#141 Posted : 27 November 2014 09:12:37
She's looking fab John, all your efforts have certainly paid off.. well done indeed....Cool Cool ... Love the build cradle too....Cool Cool
John Passmore
#142 Posted : 30 November 2014 13:21:20
Hi Alan
Thanks you for the kind words and the compliments, yes I'm quite happy with things at the moment and thinking ahead I've got a little question for you...BigGrin
With the second layer of hull planking, where it comes up under the stern either side of the stern post, what kind of glue did you use? I imagine if you use normal PVA it will keep lifting away unless you physically hold it in place for half an hour. Can't use pins and there's no way of clamping in this location so your advice in advance would be much appreciated...Cool
Kind regards
JohnP
#143 Posted : 30 November 2014 13:34:42
Hi Alan
Kind regards
JohnP
Hi John, in answer to your question I did in fact use pins and alphatic PVA adhesive, pins were map pins applyed to the side of the plank using the head of the pin to hold in place.... Link to the relevant page on my diary may help to answer a lot of your questions relating to the transom transition.... Hope it helps..
http://forum.model-space...sts&t=5013&p=55
John Passmore
#144 Posted : 01 December 2014 02:43:09
Hi Alan
Kind regards
JohnP
Hello Alan
Thanks for your prompt response and excellent advice...BigGrin
It seems my concerns were well founded as a whole can of worms was uncovered!!!LOL LOL.
Mr T's advice on your post # 1094 and your following photos are very clear and together with your advice above, I think my concerns are allayed...Cool
Many thanks and
Kind regards
JohnP
John Passmore
#145 Posted : 16 December 2014 15:15:47
Hi Everyone
Here is December 2014 Progress, it's early as I shan't be doing any more building until January as I have other things to do.
I'm still working through issue 35, marked out the hull as shown. Made a blue initially with the access hatch in measuring the 20mm height from the gunport line, which made the hatch 5mm too high...Blushing Blushing Picked up the error when marking out the top gunport line...BigGrin
Had to do a bit of experimenting for the best method of cutting out the gunports.
Issue 35 step 26 shows a little hole drilled in the centre of the gunport square...Huh Not sure why. Step 27 shows the gunport completely cutout and being trimmed...like magic!!!Huh Huh It alludes that the square was cutout using the craft knife...Huh Huh Huh I SAY NO WAY, Mr DeAgostini, it is nigh on impossible to cut bamboo cross grain with just a craft knife!!!Huh (and with slightly rheumatic hands)...Mellow So I devised a method of drilling a row of little holes just inside the vertical lines and then it was just a matter of joining the dots with the craft knife...Cool Initially used a pin drill but that was time consuming, so in deference to my penurious nature went and splashed out on an El Cheapo mini rotary tool kit for $20 - it's absolute rubbish for doing anything but drilling little holes...BigGrin But I can bin it at the end of this little caper...BigGrin BigGrin
Just got to tidy up the port holes as some of them are slightly undersize, then repaint some of the black paint inside...Cool
Progress pics below.
Kind regards to All
with best wishes for Christmas and happy building in 2015...BigGrin BigGrin
John Passmore attached the following image(s):
#146 Posted : 16 December 2014 18:14:57
Lovely work John, she's certainly coming along nicely....Cool Cool .. Cutting the bamboo with a craft knife isn't impossible but will admit it is very difficult to cut cross grain, tend to end up going through lots of blades in the process...Cool Cool .. We all find our own ways of cutting out gun ports and for me I used my trusty dremel with a routing bit attached... got to ensure you keep the dremel under control through as it does have a tendancy to try and skip away from you.... method worked for me and from there simply sanded the edges smooth and to the correct size.....Cool Cool .. As for the hole in the middle, some builders use this to help find the centre point for the gun barrel by drilling through to the dummy gun support behind....Cool Cool ... Look forward to your return in January....
Marcel
#147 Posted : 22 December 2014 06:37:09
Lovely work you did so far. I am also at the gunports, but only after I had fitted all the decks.
Sovereign of the Seas
John Passmore
#148 Posted : 24 January 2015 13:04:28
Hi Alan
Thanks for the compliment and yes I found that drilling lines of holes made for easier progress of the knife cross-grain. The knife kept jamming otherwise.
I will post Jan 2014 progress shortly
Kind regards
JohnP
John Passmore
#149 Posted : 24 January 2015 13:07:53
Hi Marcel
Thanks for the compliment. We have only received the first 2 decks so far.
JohnP
John Passmore
#150 Posted : 24 January 2015 13:52:51
Hi All
Following is my progress for January 2015.
Have received up to issue 46 but still working laboriously through issue 37 - oh yes and I finally received the missing issue 21 a couple of weeks ago...so now I have 4 unused packs of bamboo planks...Blink
All gun ports now cut out and trimmed to specified size in accordance with issue 35...although I do have a question regarding the stern-most gun port on the lower gun deck. What is this gun port for?...as the dummy cannon support piece was cut away as per issue 14 step 1...Confused Confused
First 2 pics are showing vertical reinforcement I was obliged to make on that little narrow bit between the access hatch and the gun port...Blink A little too much pressure on the craft knife and it caved in...Blushing. I had to reinforce in a few other areas as well when the bonding between some planks cracked apart...Blushing
The following pics show brown planking complete both sides per issue 36. Note my high tech construction aid - an elastic band to hold down the front end of planks while the glue cures...Cool Cool
Working on the white planks now (issue 37) and completed the first 14 rows on one side. Had a spot of bother in bonding the ends that bend up under the transom and that's where I found out what that stern-most gun port is for...to provide an anchorage point for my trusty elastic band...Laugh Laugh Laugh
Happy building to All
JohnP
#151 Posted : 24 January 2015 14:05:59
#152 Posted : 24 January 2015 14:34:08
Definitely coming along very nicely John, looking great....Cool Cool .. Don't be to concerned about the last gunport on the lower row, just make sure it is in the correct position and the right size. This gunport will end up being a closed port as can be seen on the last pic of this page on my diary....Cool Cool
http://forum.model-space...ts&t=5013&p=156
Keep up the good work, you're doing a great job....Cool Cool
#153 Posted : 24 January 2015 14:49:16
Hi Alan, BigGrin
Coming on a treat, WTG.
Some ingenious clamping methods in use as well. Cool
Keep up the good work.
Trotsky
#154 Posted : 24 January 2015 22:07:05
Nice work ...I attended the same school as your namesake S.H.S
H.M.S Victory
H.M.S Victory X Section
H.M.S Surprise under the bench
D-51
John Passmore
#155 Posted : 26 January 2015 01:35:23
stevie_o wrote:
Lovely work John, looking fabBigGrin It's amazing how creative we become when it comes to holding down planksLaugh
Thanks for looking in and nice words Steve. Yeah - a simple solution innit?...Laugh
JohnP
John Passmore
#156 Posted : 26 January 2015 01:59:11
Hi Alan
Thanks for the compliments...BigGrin Yes I found a good use for that last gun port...LOL
I've got another little problem here - I've checked the Stern Post (item 62c from issue 39) for fitting in the slot and it is far too thick to go in. Using a vernier, it measures 4.9mm thk. On checking the Keel pieces from issue 10, they are 3.6mm thk. An obvious disparity as they link up don't they?...Blink Blink So I've got 2 choices here...sand item 62c down to parity (and it won't be so even) or I can make a new piece using a piece of fret...Mellow.
Have you heard of this problem before?
JohnP
#157 Posted : 27 January 2015 00:06:20
Hi John, pleased to hear you are happy about the last gunport.... Now for the stern post and what I see as your options... This answer is not as straight forward as you may think as I had a mountain of problems with this piece and it was all down to my own carelessness and nothing to do with the instructions. Rather than try to explain it all again I would direct you to pages 66 and 67 of my diary, read the problem for yourself and how I went about correcting it... It was a very delicate and tricky fix, took time but it all worked out in the end..... Remember also, I cladded my keel and stern post with 1mm walnut sheet so in effect they are 6mm wide and not 4, this was done to match the walnut planking on the hull.
http://forum.model-space...sts&t=5013&p=66
I have checked the thickness of my keel again, it is 6mm and did not have to alter the thickness of the stern post in any way but did find it to be very tight fit into the channel created by the 2mm overhang with the planking... Because of the angle the planking strakes come in to create the overhang the gap the stern post goes into will be slightly narrower... I very carefully filed away some of the inside of the overhanging planks down the complete length, I then inserted the stern post from the top and slid it downwards very slowly, checking to see where it was sticking and used reverse action flat head tweezers to prize the gap open slightly... had to be very very careful doing this to ensure I didn't apply too much pressure and crack or break any planks... Can tell you my heart was in my mouth a few times but it worked in the end for me....Cool Cool Having said all that, I'm not so sure this would work for you because of the differences in thicknesses you say you have but it is something you can look at but would be a very brave fix to undertake....Blink Blink Blink In your case, I would cut a channel 0.5mm deep, 2mm wide (the same size as your overhang), down the length of either side of sternpost to give an easier fit... This in effect would give you the same finish as I achieved when adding the 1mm walnut either side leaving it 2mm short from the edge. Not sure what tools you have to do this but with care and attention you shouldn't notice any difference in thickness.....Cool Cool .. Of course, you have your option also of making a new stern post out of some spare fret of the required thickness, if you have any spare that is....Cool Cool .. You could also reduce the size of the overhang to make fitting easier but you need some overhang to hide the join between the stern post and the false keel plus file either edge of the stern post to make it a little narrower and easier to insert....
Sorry this is probably not the straight forward answer you were looking for but having gone through my diary on this it brought back some memories of how I dealt with a difficult and challenging problem.. I'd be happy to exchange further ideas with you before you tackle the problem but you have to choose the option you are most comfortable with and having seen your progress to date I feel confident you will fix this problem too.... Good luck with it and look forward to seeing how you get on....
Best regards
John Passmore
#158 Posted : 27 January 2015 09:14:40
Hi Alan
Thank you for your long missive! It was very informative...Cool
I've had a look at your pages 66 and 67 and whilst it has given me ideas, my problem is slightly different than yours was...Blink Your problem was horrendous and definately would have given me heart burn!...Laugh
I'm pretty sure I can make the stern post fit in the slot, but as I said, it is of a different thickness to the keel piece by a margin of around 1.5mm so there will be a step at where the two pieces join...Blink Blink
This must be a design/production error.
I have laid the 2 pieces out on my desk so you can see it better...Cool
and I think the solution is to gradually sand/file the step smoothly into the keel piece...Cool What do you think Alan - it might look a bit weird?...Blink
JohnP
#159 Posted : 27 January 2015 23:37:51
Hi Alan
JohnP
Hi John, a pic always gives greater clarity and having seen it I would do it this way... First, where the stern post goes into the slot, file the edges slightly to narrow the width (as if you were going to make it wedge shaped), file just enough to get it started into the slot and be gently pushed home.
Correct me if I'm wrong but it is your intention to paint the lower hull. If this is correct then I would use planking strips left over from the second layer and apply along the lengths of both sides of the keel. This would bring the keel a lot closer to the width of your stern post.... Once done and you paint then it wouldn't be noticed... Just another thought for you to consider and I think better than trying to narrow the stern post without it being noticed...
Hope this helps.
John Passmore
#160 Posted : 28 January 2015 04:08:47
Hi Alan
JohnP
Hope this helps.
Hi Alan
Many thanks for your prompt response...BigGrin
Yes - I've decided to paint the hull per the Official Build. I don't feel confident enough to stain it like yours but certainly would have preferred to do it that way as it looks terrific...BigGrin BigGrin
Yes that is how I intend to fit the stern post - chamfer the length both sides by 2mm back from the edge. That will create a kind of long wedge which should push straight into the slot...Cool
I've since noticed that the supplied part 62c is also overlength by about 15mm, and as both ends are angled correctly I'm wondering if this is the correct piece for this kit at all?...Confused
Using the white planks to blend in to the stern post is a great idea Alan and I shall give it consideration, but it does mean I'll have to run this modification the full length of the keel - up to the prow assembly to achieve continuity. Many thanks for the tip...Cool
Kind regards
JohnP
21 Pages «<678910>»
This page was generated in 0.323 seconds.
