162 Pages «<148149150151152>»
#2981 Posted : 29 November 2014 22:49:54
davetwin wrote:
Fantastic work Alan, she really is lookng quite stunning, you have done such and amazing job so far
Thank you Dave for the very kind comments.... she's a challenge but a very enjoyable one....Cool Cool .. Thanks again...
#2982 Posted : 29 November 2014 22:54:50
Got the Mizzen mast completed today... I mentioned in my last post about drilling two small holes in the main mast cap... decided to drill the same two holes in all the mast caps, reason being I want to feed the halfyards over the top of the mast cap and back down through the small holes before fitting to the yards....Blink Blink .. Assembly again was pretty straight forward and ensured everything was orientated correctly and properly lined up..... Cool Cool .. Masts sitting in position but not glued as yet.... Tomorrow will make a start on the foremast which probably has the most work of all to be done.....Cool Cool .. Happy building all...
#2983 Posted : 29 November 2014 23:00:47
Hi Alan, BigGrin
More stunning work.
Cool Cool Cool Cool
#2984 Posted : 29 November 2014 23:12:35
delboy271155 wrote:
Hi Alan, BigGrin
More stunning work.
Cool Cool Cool Cool
Thanks Derek, appreciate you looking in and the positive comments....Cool Cool
#2985 Posted : 29 November 2014 23:47:20
That is some really nice work Alan
You can see all the love and attention to detail that has gone into this, it is going to be such a stunning model that you can rightfully be proud off Cool
#2986 Posted : 30 November 2014 10:29:29
Thanks Dave, I have a sense of achievement with this build but there is still a lot to get on with... Very happy with how its all going right now...Cool Cool Appreciate the supportive comments...
#2987 Posted : 04 December 2014 23:15:42
Hi guys, well issue 114 at long last is now complete with the exception of actually gluing in place the bowsprit, this will be done when the foremast is set. Other 3 masts have been secured in place now... This issue also included the adding of yet more bling to the forward section plus more gun port lids....Cool Cool . A very long issue, lots of work but am very pleased with the results....Cool Cool
Next issue starts with more bling and the first of the lower shrouds....Blink Blink .. The rigging starts!!!! Happy building all.
Ponty
#2988 Posted : 04 December 2014 23:22:28
Hi Alan,
Your build is just stunningDrool Drool
You have a true craft and I'm honored to be able to watch your build.
#2989 Posted : 04 December 2014 23:22:52
#2990 Posted : 04 December 2014 23:43:14
Ponty wrote:
Hi Alan,
Thank you Barry, I'm humbled by your kind words and honoured to have you looking in.... very much appreciated....Cool Cool
#2991 Posted : 04 December 2014 23:44:37
stevie_o wrote:
Very nice Alan, more bling next issue...cant believe there's any space left for itLaugh
Thanks Stevie, appreciated and there is still quite a bit of bling to add yet.... Cool Cool . It's amazing she could still float with it all attached....BigGrin BigGrin
#2992 Posted : 13 December 2014 23:10:09
Finally finished issue 115 and this one started off with the painting and fitting of yet more bling.... It also had me painting bling that had already been fitted to the ship in previous issues, this made it a little more fiddly that it usually is....Cool Cool .. Once the bling was fitted I got down to the task of starting the rigging with the fitting of the shrouds on the foremast.... Cool Cool .. A slow and painstaking process but at the same time extremely enjoyable even if I say I found this to be probably the hardest part of the build to date but did get easier as I improved on my technique.... The white bobbin you see hanging from the lower fighting top was put there to help me ensure I kept the mast truly vertical whilst tensioning the shrouds, found it worked very well for me....Cool Cool .. Onto issue 116 which consists of more bling plus shrouds for the main and mizzen masts, ratlines and a few other things... Looking at the instructions this is going to be another long session.....Cool Cool .. So until next update, happy building all....Cool Cool
#2993 Posted : 13 December 2014 23:17:51
BigGrin Great work as always and very neat start to the rigging, simple but effective way to keep the mast straight tooCool
der Gohfelder
#2994 Posted : 13 December 2014 23:36:51
Hi Alan!
A nice work you made, I like it !!!
Kind regards, Bernd
#2995 Posted : 14 December 2014 03:36:51
Great work as always Alan, it's sad to think that after following this for so long and getting so much enjoyment from it that it will be coming to an end soon.
#2996 Posted : 14 December 2014 09:12:41
Thanks Andy, sometimes the simple solutions are the best, main thing is it works.... appreciate your comments as always.....Cool Cool
@Bernd, thanks again for looking in and your comments.....Cool
@David, it will be sad to know its finished but at the same time that gives back some free time to get started on something else..... Appreciate you looking in and your comments as always.....Cool Cool
#2997 Posted : 14 December 2014 09:45:42
Hi Alan like the bobbin idea. Now if you wrap some paper around the mast and tape it together sobthat it toiches the bobbin you will see if the mast moves iven by a fraction of mm
Looking forward to your first rigging experiance ๐Ÿ˜๐Ÿ˜๐Ÿ˜Ž
โ€œWhenever you find yourself on the side of the majority, it is time to pause and reflect.โ€
#2998 Posted : 14 December 2014 10:41:28
Thanks for looking in Jase and for the tip, appreciated....Cool Cool
#2999 Posted : 14 December 2014 12:15:18
Hi Alan,
I do love the work on the rigging very skilful, as Dave said it is sad to see the end of a build,154 pages! that's a record in it's self on this Forum, that alone shows the time and effort you have put into this build, and for other Sots builders to follow. Your build is one of those that will stay in my mind for a long time and others to, so even when finished it will not end.
Trev.
#3000 Posted : 14 December 2014 15:22:25
tf64 wrote:
Hi Alan,
Trev.
I have to agree. more than anything it is clear you enjoyed every moment and thats what it is all about BigGrin Cool
This page was generated in 0.416 seconds.
