Hi All, Just purchased an "Academy" kit of the "GRAF SPEE" at a scale of 1:350. On the 17th December this year, it will be the 75th anniversary of the scuttling of this ship, just outside of Montevideo harbour. The guy selling the kit is out of the country for the next couple of days, so delivery will be delayed slightly. Never mind, I am going to try my best to do this as an out of the box build by the 17th December. (NO PROMISES)Especially with my day to day work load. Will be an interesting task. Wish me luck EH!!!! Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 sounds good and good luck with her Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: sounds good and good luck with her Cheers Andy, Will not want to make a mess of this but, will do my best to get it done by the 17th Dec. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looking forward to this alot as i have a 'thing' for German wsrships Whos paints eill you be using?? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
The clock is ticking Derek, good luck with the build and I'll be following your progress as usual.... Regards Alan
jase wrote:Looking forward to this alot as i have a 'thing' for German wsrships Whos paints eill you be using?? Hi Jase, Thanks for looking in, as for the paints I`m open to suggestions, but need to be able to access them pretty quick. Don`t even know what is needed until kit arrives.(Research time) Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Gandale wrote:The clock is ticking Derek, good luck with the build and I'll be following your progress as usual.... Regards Alan Hi Alan, This ones gonna bring a whole new meaning to "out of the box". I won`t have time for it to touch the table before it will need opening.  Thanks for your support. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, Here`s a link to some pics of the Graf Spee in Montevideo harbour. The pics clearly show the damage inflicted by the Royal Navy. Graf Spee in MontevideoRegards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:jase wrote:Looking forward to this alot as i have a 'thing' for German wsrships Whos paints eill you be using?? Hi Jase, Thanks for looking in, as for the paints I`m open to suggestions, but need to be able to access them pretty quick. Don`t even know what is needed until kit arrives.(Research time) Regards delboy271155 (Derek) this should cover what you need. jase https://airbrushes.com/p...fo.php?products_id=2844
Looking forward to this build, you have certainly set yourself a tight deadline but wish you the best of luck in your challenge
jase wrote:delboy271155 wrote:jase wrote:Looking forward to this alot as i have a 'thing' for German wsrships Whos paints eill you be using?? Hi Jase, Thanks for looking in, as for the paints I`m open to suggestions, but need to be able to access them pretty quick. Don`t even know what is needed until kit arrives.(Research time) Regards delboy271155 (Derek) this should cover what you need. jase https://airbrushes.com/p...fo.php?products_id=2844
Hi Jase, That`s great, thanks very much. Looks like a speedy delivery service as well. I have most of these colours in the Tamiya equivalents, but will wait till the kit arrives before making a final decision. Thanks again for your input. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
davetwin wrote:Looking forward to this build, you have certainly set yourself a tight deadline but wish you the best of luck in your challenge Hi Davetwin, Yep a tight deadline indeed, but, it could get tighter yet depending on kit delivery time. Will do my best to hit the deadline, but as stated before I`m not going to spoil this build just to hit the deadline. (Will do my best). Thanks for looking in and your support. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:davetwin wrote:Looking forward to this build, you have certainly set yourself a tight deadline but wish you the best of luck in your challenge Hi Davetwin, Yep a tight deadline indeed, but, it could get tighter yet depending on kit delivery time. Will do my best to hit the deadline, but as stated before I`m not going to spoil this build just to hit the deadline. (Will do my best). Thanks for looking in and your support. Regards delboy271155 (Derek) Very wise Del, the build quality and enjoyment come before the deadline, Im sure it will be a a fitting tribute though Steve
stevie_o wrote:delboy271155 wrote:davetwin wrote:Looking forward to this build, you have certainly set yourself a tight deadline but wish you the best of luck in your challenge Hi Davetwin, Yep a tight deadline indeed, but, it could get tighter yet depending on kit delivery time. Will do my best to hit the deadline, but as stated before I`m not going to spoil this build just to hit the deadline. (Will do my best). Thanks for looking in and your support. Regards delboy271155 (Derek) Very wise Del, the build quality and enjoyment come before the deadline, Im sure it will be a a fitting tribute though Steve Hi Steve, Thanks for your interest and agree that the end result must take precedence. Thankfully, between other commitments and work restrictions I can see some good modelling time, but only TIME will tell. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Guest (7)
