162 Pages «<146147148149150>»
#2941 Posted : 21 November 2014 12:44:00
Hi Alan.
Cannons look realy good, know the feeling on gun rigging took me four hours to make up 10 gun tackles on my victory tyhe other night still got ten to make. look forward to seeing your progress ianCool Cool BigGrin
#2942 Posted : 21 November 2014 23:17:56
ian smith wrote:
Hi Alan.
Thanks Ian, appreciated.... Pleased the cannon fitting is over but low and behold, still masses of blocks to make up yet....Blink Blink .. I'll be dreaming of blocks very soon at this rate.....BigGrin BigGrin
#2943 Posted : 22 November 2014 10:13:53
BigGrin Stunning work on the cannons Alan . I still have to do the ones on the top decks hay ho Crying
Bril work m8 happy building rgd MartynCool
#2944 Posted : 22 November 2014 10:50:22
Thanks for the kind comments Martyn.... Cool Cool .. Am sure you will enjoy fitting all the cannons as much as I did but be prepared for a lengthy job especially if you are going down the full rigging route....Cool Cool .. Thanks again..
#2945 Posted : 22 November 2014 13:23:21
Top work as usual Alan and a joy to see this build come together Cool
Spencer
#2946 Posted : 22 November 2014 19:53:14
Spencer
Thanks Spencer and a joy to put together.... Glad you're enjoying the build....Cool Cool.. Working on the bowsprit just now so hopefully will be posting again soon...
#2947 Posted : 22 November 2014 20:04:44
Hi Alan,
Cannons look the part, how are your eyes after that rigging, and what a great idea with the cocktail sticks, thank you for posting.
Trev.
#2948 Posted : 22 November 2014 23:14:21
tf64 wrote:
Hi Alan,
Trev.
Thanks Trev, eyeballs are fine thank but only due to frequent breaks and the use of a good set of optivisors.... at my age I couldn't work without them....Cool Cool .. Thanks again...
#2949 Posted : 23 November 2014 08:19:50
BigGrin Hi Alen
Very nice work, the cocktail sticks certainly enhance those bulkheads and simplicity itself to do.
#2950 Posted : 23 November 2014 10:06:37
arpurchase wrote:
BigGrin Hi Alen
Thanks Andy, just felt the bulkheads needed a little more definition and was happy with the results.... Cool Cool .. Thanks again..
#2951 Posted : 23 November 2014 23:52:44
Hi everyone, issue 113 is finally finished today... will say however, now I'm heading towards the final few issues of this build I am noticing a marked increase in the amount of work to be done on each issue.... Issue 113 has probably had the most work required to date with the final part being the making up of the bowsprit... This started with applying the bindings as per the mast plan, moving on to fitting all the eyelets and blocks... Must point out here I made up all the blocks and attached them to eyelets prior to fitting, thought this would be easier than trying to fit them when the bowsprit and mast section was completed...Cool Cool . Next task was to fit the rigging blocks to the fighting top again as per the mast plan...Cool Cool
Next job was to start making up the forward mast sections of the bowsprit, found here the larger of the mast holes on the upper mast supports was slightly to big for the mast, solved this by inserting slivers of sapele strips into the mast holes and painting black leaving me with a snug fit. Assembled the mast sections together and then attached all the eyelets and rigging blocks drilling through the mast supports and into the mast themselves...Cool Cool
Final part was to fit the fighting top onto the bowsprit and inserting the completed mast sections, ensuring the fighting top was level and the forward mast section lined up with the bowsprit....Cool Cool
An enjoyable part of the build now concluded with the bowsprit sitting in position, this has not been glued as yet, that will be done further down the line.....Cool Cool .. Happy building all....
#2952 Posted : 24 November 2014 10:09:56
BigGrin Lovely work on the Bowsprit Alan looking forward to seeing more BigGrin Rgd Martym
#2953 Posted : 24 November 2014 13:26:27
Hi Alan.
Bow sprit looks very nice. Looks like your progress will be upwards from noe on. look forward to seeing your masts going on. Ian Cool Cool BigGrin
#2954 Posted : 24 November 2014 23:13:28
Thanks Martyn, getting closer to getting started on the rigging.... sure there will lots of fun to come working my way through that....Cool Cool
#2955 Posted : 24 November 2014 23:14:50
ian smith wrote:
Hi Alan.
Thanks Ian, we just keep plodding along until there is nothing left to do.....Cool Cool Thanks again...
#2956 Posted : 24 November 2014 23:23:09
Looks fantastic AlanBigGrin You got to have eyes everywhere once that bowsprit get glued in, unbelievable how many times you forget it's there and catch something on itLaugh ...or is that just me!
#2957 Posted : 24 November 2014 23:33:33
Thanks Stevie, thanks for the warning, will have to be extra careful as more and more of the mast fittings are put in place,,, Cool Cool .. Thanks again..
#2958 Posted : 24 November 2014 23:41:11
Beautiful work there Alan, and Stevie's right, it's so easy to forget that thing's sticking out so far (nearly doubles the turning radius when the hull is on a turntable too!Blushing )
Many years ago when I helped Dad to build our extension we fitted in the wooden full length open door frame months ahead of putting in the glass - then eventually after weeks of stepping through the empty frame we added the glass - guess what happened next!Crying
And well done in fixing the loose mast, banging in big wooden wedges is just how they did it for real as well!Cool
Keep them coming!
Robin
samson
#2959 Posted : 24 November 2014 23:47:30
Hi Alan
So finly Riggin BigGrin . looking amasing Cool .
Cheers
Jens
#2960 Posted : 25 November 2014 00:28:24
Keep them coming!
Robin
Thanks Robin for those kind words...Cool Cool .. A turntable is something I need to invest in and am on the lookout for one that will be strong and large enough to do the job....Cool Cool .. The idea of snagging things and ending up with breakages is something I will have to try and be very careful with..... Cool Cool ..Thanks again...
This page was generated in 0.371 seconds.
