Andylangtree`s build Options
andylangtree
#1 Posted : 29 March 2010 19:09:22
Anchor. Did not use thread supplied to wrap around, did not appear to be enough, i used thread from an airfix build i did previously.
Not going to do the hull until all parts received.
thescrameth
#2 Posted : 29 March 2010 21:10:51
Rank: Amateur Level 1
hi, there nice work. But how do you upload pictures onto the forum?
andylangtree
#3 Posted : 02 April 2010 14:01:43
Anchor redone with puddening
andylangtree attached the following image(s):
Capt Stedders
#4 Posted : 07 April 2010 19:26:04
Got to have puddening and siezings, right? It's fiddly but well worth it. well done.
I still reckon that the supplied anchor rope looks way too dark. Might I suggest that you try bleaching it? (overnight, neat bleach).
Schnellboots on back burner
Tools.
#5 Posted : 07 April 2010 22:11:17
i agree the anchor rope is way to dark. i was thinking about bleaching then soaking in a waterd down paint to ad a tint
andylangtree
#6 Posted : 08 April 2010 17:27:06
Cheers, the puddening and seizing was very fiddly but looks better with it.
Redone the cannon, idea from Jase. Looks ok but again very fiddly. Purchased 0.8mm thread from Miskin models, eyes from garden wire.
Capt Stedders
#7 Posted : 08 April 2010 20:35:45
Salutations for attempting the securing rope over the barrel Blink *claps*
Most fiddly indeed! I salute your skill with the string!
My only critique (and its only a small one) would be that the rope is all of the same thickness and looks slightly out of scale with the cannon - it also looks a little 'floaty'. Have you considered painting the rope down with either some thinned varish before probing it into shape, giving the illusion of weight? (This will also reduce the wooliness of the twine by dampening down most of the stray fibers
Tools.
andylangtree
#8 Posted : 08 April 2010 20:55:38
Thanks for that, will be considering your suggestions and will more than likely give it a go.
#9 Posted : 08 April 2010 23:33:33
love the cannon humbuled that i have offerd insperation. for my part i yesterday purchased some green stuff after seeing what a differance it can make. its great we can all share and learn!!BigGrin
jay7792
#10 Posted : 11 April 2010 18:16:14
Hi, love the new and improved cannon!! The extra work that you have put into it has really payed off.BigGrin
_____________________________________
Currently building:-
Deagostini HMS Victory
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
andylangtree
#11 Posted : 03 June 2010 14:49:02
Anchor redone, 15mm ring and 2.5mm rope, rope maybe out of scale but will be able to tell better when attached to ship.
andylangtree
#12 Posted : 03 June 2010 14:54:39
Launch planked, i did not use the planks supplied but some i had left over from another build that went badly wrong, hate cameras cause they make everything look really bad. The gaps should not really show when painted.
andylangtree
#13 Posted : 13 June 2010 13:21:10
Launch now painted and despite how the launch looked in previous post no filler was added, the sanding sealer covered the small gaps. The paint job is not brilliant but i struggle with the painting, i have watered down the paint and applied 4 coats of white and its not too bad.
This page was generated in 0.432 seconds.
