 Rank: Pro     Groups: Registered
Joined: 25/04/2014 Posts: 374 Points: 1,134 Location: Mandurah W.Australia
Gandale wrote:Hi John, looks to me like you are doing just fine. The small gaps on the bow can be filled in with wood filler when you come to the sanding stage, larger gaps can be filled with tapered planks... Remember also, everything will be covered up by the second layer so what you are trying to achieve with the first layer is a good smooth flow to the hull and a good grouding ready for the second layer... Link below is to the same area on my build and you will see your's is looking very similar so continue as you are. http://forum.model-space...sts&t=5013&p=22
Keep following the build instructions and keep a close watch on Mr T's official diary especially from issued 22. Will be watching to see how you get on.... Regards Alan Hi Alan Thanks for the nice comments and confidence booster...I was just getting a bit worried about the look of things...and yes I'm following Mr T's official build with the utmost close scrutiny as well as the magazine... Your advice is very sound of course and is appreciated... Regards JohnP
jonny7england wrote:Looking really good John...Well done mate!!  Hi Jonny Thanks for looking in and the nice comment... Regards JohnP
George1 wrote:Hi John. Looking good mate.  Yes you will find that there are a number of tapered planks from bow to stern re hull bottom. I checked Alan's and Tomicks builds counting off planks to see when and where to do. A couple do not go to the bow and finish around rib 5 and 7 to the stern which eventuates in more or less a straighter gap between hull planking and bow to stern planking which is then easier to fill in. As Alan says These planks are for cover and shape for 2nd lot of planking so as long as you're happy with the final finish a few pointed strakes won't matter.  Does get a little tricky around stern re issues 23-25.I'm gonna' be following Alan and Tomick's build closely. Re your "Burnisher Query" my thread: You can get from bigger Gun Shops. My son got mine from the Midland Gun Shop, Great Eastern Highway. Don't know name of shop but easy to find in yellow pages under 'Guns or Firearms". Regards George G'day George - how'r yer goin'? Thanks for looking in and responding. Yes, Alan's put my mind at rest re the planks and I will also follow closely Mr T's official build diary... I wont get issue 21 till Thursday so I'm just about out of planks and now fiddling with the ships' boat. There are no gunsmiths in Mandurah, the nearest apart from Perth, is Bunbury or Busselton. The 2 I spoke to were not sure what burnishing fluid was, mentioning 'blueing fluid' instead. Not being a chemist I don't have a clue. I'll check out that one you mentioned in Midland - thanks for the pointer mate. Regards JohnP
John Hope the building is going well. While I cannot be sure if it would ship from the USA to Australia being a liquid the following may give you an idea of what this blackening agent actually is. There are other brands and it may be possible you have a stockist in Australia via one of your model shops - maybe one that specialises in model railways. http://www.micromark.com...en-it-4-fl-oz,7267.html
The following link contains some useful info in using this and some of the other products in the range. http://rrmodelcraftsman....aftsmantoolchest_02.php
Happy modelling Tony Happy Modelling
birdaj2 wrote:John Hope the building is going well. While I cannot be sure if it would ship from the USA to Australia being a liquid the following may give you an idea of what this blackening agent actually is. There are other brands and it may be possible you have a stockist in Australia via one of your model shops - maybe one that specialises in model railways. http://www.micromark.com...en-it-4-fl-oz,7267.html
Happy modelling Tony G'day Tony Many thanks for your useful input which in turn led me via www to possible Australian suppliers in Perth... I was in Swindon last year - got family in Wiltshire. Nice part of the world... Regards JohnP
Hi All Progress for August 2014 - with some pictures; * Repainted the ships boat, blackened mesh and fitted, assembled duck boards outside the boat, painted, then installed; * Finished laying trial deck planking to middle deck, leaving plenty of space for dummy cannon supports. Will clear lacquer prior to fitting third deck; * Continued hull planking up to issue 25. Got the plank ends up the stern post in a fairly straight line. Made a bit of a blue with the bow planking - the first 4 planks from the false keel are finished too long, taking up too much space towards the bows - consequently I ran out of room at the first bow former. I've compromised by ending bottom planks along the last upper hull plank... Overall I'm happy with my planking, but any comments or advice will be appreciated... Regards JohnP John Passmore attached the following image(s):
Hi John, coming along very nicely and don't worry too much about running out of room at the bow for the planks, you're doing just fine.... remember, this layer is about getting a nice smooth shape to the hull, clean lines all ready for the final layer of planks which of course is the most important.....  .. Deck planking looking great, very nice work there... Keep posting those pics.... Regards Alan
Joined: 16/03/2014 Posts: 516 Points: 1,563 Location: Perth Western Australia
Hi John. Everything looking good mate. Looks like you've got deck planking under control too. Like Alan said you'll see where you need to put in pointed strakes to alleviate the curvature from bow to stern as that gap closes. The only assistance I can offer is watch when the gap closes at rib 26 or thereabouts to the stern to ensure planks close off that gap. I nearly made a mistake when following the narrowing of three planks at the stern as shown in Official Build as I had the start of the taper bow side of rib 26 and would have left a skinny gap at that point where I should have started the taper stern side of rib 26 and the three planks of full width would have closed it off perfectly. Better that you might have to narrow a plank there to fit than the planks not filling or you'll be having to have pointed strakes opposite one another.  Of course as Alan says the most important thing is filling in with this first layer of planks. Regards George Building HMS SOTS
Hi Everyone - I'm baaa-aaack! Sorry I've been AWOL for a while but my 14 year old wind-up lap top gave up the ghost a couple of months ago and I was loathe to go out and buy one of these new- fangled things with different op systems... Something about teaching old dogs new tricks...not possible in my case either...  . Anyhow, the wife eventually went out and bought me a new one, so then I was FORCED to bite the bullet and learn my way around this new device. This has taken a bit more time, and then I had trouble with passwords in logging on to this forum... Notwithstanding the foregoing trials and tribulations, I have been pottering along with my SotS build and have attached some pics of my progress to date. BTW, issue 21 never showed up but I managed quite well without it materially speaking, and still have 3 unopened packs of bamboo on completion of hull planking Kind regards to all JohnP John Passmore attached the following image(s):
 Welcome back to the forum John . Lovely work on the planking m8  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Martyn Ingram wrote: Welcome back to the forum John . Lovely work on the planking m8  Rgd Martyn Thanks Martyn. 'Twas a bit of a frustrating period but gr8 to be back... Rgds JohnP
Hi All Below are some pics showing November Progress with completion of hull planking... The last picture shows detail of planks ending at the Starboard side gallery foundation plate. When I reached the top there was room only for one short 50mm piece whereas instruction says there should be two pieces. But if I put the second piece in, it would extend well beyond the top of the stern gallery... There are 16 layers of planks from the bottom corner of the gallery to the top - the same as in the magazine and Mr T's official build diary, so I'm not sure how this situation occurred... So can anyone advise if there would be a detrimental effect to the future build by omitting the second short piece - bearing in mind there would be only half the perpendicular elevation at the forward end of the short piece... Rgds to All JohnP John Passmore attached the following image(s):
Joined: 19/07/2014 Posts: 209 Points: 580 Location: Delecombe, Victoria, Australia
She looks fantastic John, great work on the planking. Eugene.
hi john, very nice job there, keep up the good work. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Hi John, lovely work and its great to see you back publishing your progress...  .. Regarding your question, it really does not matter if the planks go above the stern gallery section as later in the build you will do some marking and some trimming back of the planks to give you the overall height... Variations in this part of the build is very common so just carry on as you are doing and add the extra plank.... Hope this helps however, any queries then let me know. Regards Alan
Whizgig wrote:She looks fantastic John, great work on the planking. Eugene. Hi Eugene Thanks for looking in and nice comments. Yeah, the planking was awkward to start with but once I got accustomed to it, it became easier and quite enjoyable. You will find it a lot easier with the balsa infills as well. Kind regards JohnP
karl1113 wrote:hi john, very nice job there, keep up the good work. Hi Karl Thanks for looking in and the nice comment. Yep - I'm enjoying this little caper... Kind regards JohnP
Gandale wrote:Hi John, lovely work and its great to see you back publishing your progress...  .. Regarding your question, it really does not matter if the planks go above the stern gallery section as later in the build you will do some marking and some trimming back of the planks to give you the overall height... Variations in this part of the build is very common so just carry on as you are doing and add the extra plank.... Hope this helps however, any queries then let me know. Regards Alan Hi Alan Yes it's good to be back on board and thanks for the compliment. Thanks also for the - as always - sound advice re the second short plank and which has been followed today...It doesn't look too bad... You will note I have clear lacquered the middle deck planking in accordance with your earlier advice and it looks really good. A bit orangey in the photo but that is just the artificial light I have in here. The colour is actually very similar to the hull planking - which is how I wanted it... Kind regards JohnP
Hi John, pleased the advice worked out for you.... Decking looks great, a job well done..... Regards Alan
Hi Everyone Collected issue 38 from the newsagent today - at last - a change of scenery!!!  - but alas - I can't get to it yet as I still have the procedures of issues 35 and 36 to carry out... So not a lot of further progress for November, I was obliged to modify my build cradle as it was unstable whenever weight/pressure was applied to the bows or stern and tended to tip downwards...  Fixed that with two extension bars added... At the same time installed additional screws to allow for height leveling adjustment on all quarters, and extend width of cradle to accommodate thickness of second layer of planking and protective cushioning... I've sanded and filled one side of the hull and quite happy with the result - smooth as a baby's bum now... Kind regards to All JohnP John Passmore attached the following image(s):
