Joined: 26/07/2010 Posts: 25 Points: 68 Location: Dunstable, UK
When I painted the launch I found that the wood grain showed though quite a bit. Somewhere in this forum it was suggested to use sanding sealant to fill the grain and provide a better paint finish. As a test I painted an area of some of the spare plywood from the launch build with just paint and another area first with 2 coats of sanding sealant and then the paint.
The area with the sanding sealant did have a better finish but I noticed that the paint would flake off much more easily than the area with no sanding sealant.
Should I be using acrylic primer after applying the sanding sealant and what if the best method to obtain a good paint finish that is well bonded to the wood and will not flake off? Perhaps a coat of acrylic varnish is what is needed. Can anyone help?
Oops...should have put this post in the General Build Discussions area.
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
I use PVA & Water 50% Dilute - gives a good sandable (whet & Dry) finish and cheep You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
the sanding sealant need to be finely rubbed down with wet& dry grade 400 should do it,then thin your paint down 'bout 60% paint and apply several coats,then a final rub down with 600 wet & dry used wet,and then final coat 'bout 50/50 and that should do it. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Sounds like a couple of good solutions which I will test out. Do you also use acrylic primer which I have heard people mention?
 Rank: Pro  Groups: Registered
Joined: 23/03/2010 Posts: 202 Points: 528 Location: Bedfordshire
Quote:I use a high build acrylic primer or a filler primer bought from any car accessory shop gets you a super smooth finish when you use 1200 wet and dry on itBigGrin BigGrin BigGrin hope this helps Thanks, I will check out my local Halfords. It it a spray can or paintbush primer?
