Sanding sealant and paint issue Options
doobeiferkin
#1 Posted : 22 August 2010 21:46:05
Rank: Beginner Level 3
When I painted the launch I found that the wood grain showed though quite a bit. Somewhere in this forum it was suggested to use sanding sealant to fill the grain and provide a better paint finish. As a test I painted an area of some of the spare plywood from the launch build with just paint and another area first with 2 coats of sanding sealant and then the paint.
The area with the sanding sealant did have a better finish but I noticed that the paint would flake off much more easily than the area with no sanding sealant.
Should I be using acrylic primer after applying the sanding sealant and what if the best method to obtain a good paint finish that is well bonded to the wood and will not flake off? Perhaps a coat of acrylic varnish is what is needed. Can anyone help?
doobeiferkin
#2 Posted : 22 August 2010 21:48:26
Oops...should have put this post in the General Build Discussions area.
riff-raff
#3 Posted : 22 August 2010 22:12:06
I use PVA & Water 50% Dilute - gives a good sandable (whet & Dry) finish and cheep BigGrin BigGrin
Built:
#4 Posted : 22 August 2010 22:13:56
the sanding sealant need to be finely rubbed down with wet& dry grade 400 should do it,then thin your paint down 'bout 60% paint and apply several coats,then a final rub down with 600 wet & dry used wet,and then final coat 'bout 50/50 and that should do it.
doobeiferkin
#5 Posted : 22 August 2010 22:25:58
Sounds like a couple of good solutions which I will test out. Do you also use acrylic primer which I have heard people mention?
Allan
#6 Posted : 23 August 2010 06:57:01
I use a high build acrylic primer or a filler primer bought from any car accessory shop gets
you a super smooth finish when you use 1200 wet and dry on itBigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
hope this helps
doobeiferkin
#7 Posted : 25 August 2010 23:14:42
hope this helps
Thanks, I will check out my local Halfords. It it a spray can or paintbush primer?
