DeAgostini Issue 114 alert notice
Due to production problems, you should NOT proceed beyond Step 9 of Issue 114 until further notice.
New information will be provided shortly so that you will be able to proceed with the 114 build.
You should also follow the Issue 103 update information in the link at post #2 below.
Issues and parts will continue to be supplied as normal. DeAgostini apologise for any inconvenience this may cause.
Amends update
The amendment insert information, will go into Retail (newsagent) copies of issue 117 & 118
Subscribers - the amendment insert information will be provided with your subscription pack containing Issue 114.
You can continue with Step 10 and onwards of Issue 114 once you have carried out the amendments.
Steps 1 - 22 of Issue 115 can be carried out regardless of making the amendments.
 Rank: Beginner Level 1 Groups: Registered
Just to be sure I understand this problem correctly. Is it a instructions problem only or are there also faulty parts involved?
It's an instructions problem and making a slight change to one of the parts which is corrected by the amends info
Ok, thnx for the info. Just what i wanted to understand
