10 Pages «<678910>
Hachette Stuka JU87 - Take off Options
#141 Posted : 01 June 2014 23:54:21
delboy271155 wrote:
Hi All, BigGrin BigGrin
Many, many thanks to all the posts above, Cool Cool Cool
Only there is one thing to add. Blink
My last post should have ended like this. !!!
_______________________________________________________
With the above parts constructed, I now have ample stuff that needs spraying.
So, will on Monday be having an all in spraying session.
Pics to be posted soon.
____________________________________________________________
Only it ended in real time like this.
Mobile phone rings:
Lady from flat below.
"HELP Bob`s having a heart attack" Crying
_____________________________________________________________
Good news is that, Bob, now has a stent fitted in the main artery to his heart and the prognosis is good.
Thank goodness for advanced First-Aid from my diving days.
So again,
Well done Derek, hats off to you... Cool Cool Even where people are trained in first aid they never know how they will react if and when they ever have to put it into practice.... Very pleased to hear Bob's prognosis is good.... well done again..... Cool Cool
#142 Posted : 03 June 2014 08:40:57
Derek,
Well done to the above, good job you were there and had that First aid training.
Hope you get on well with your spraying.
Trev.
#143 Posted : 31 October 2014 19:06:46
Well here we go again, BigGrin BigGrin
Apologies for the delay in this builds delay.
I`ve had numerous other things going on, then a major refit of my flat.
In between there was a lovely holiday in Cyprus.
So, all that business out the way, let`s get on with this build.
Cool Cool Cool Cool Cool
When I left this diary for a while, I was at the stage of having the centre airframe almost complete.
That airframe then needed a paint job.
First issue was this:
Paint selected (as shown earlier) went on fine.
Then Cursing peeled off like an orange skin.
So, primed with "Tamiya" light grey, then top coated with "Vallejo" RAL7021 and all`s fine.
Here`s the result of all that effort.Pic 1
From here, I had numerous parts built that were also in need of a paint job.
Firstly the top face of the pilot`s facia panel. Pic 2
Following on from this came the bomb aiming unit, the main bulkheads for each end of the centre fuselage section and the backplate for the pilot`s control panel. Pic 3-6
So, back to a little construction session.
I fitted the two main bulkhead sections to the centre fuselage section.
"WORD of WARNING"
Before you fit these bulkheads, check that everything lines up at least twice.
The reason I say this is because of the following:
The larger bulkhead has 16 locating points
The smaller bulkhead has 14 locating points
If all of these locaters are not in place at this point, then the rest of the fuselage will be out of line.Pic 7
The oil tanks also needed a coat of paint.
The results shown below will be enhanced at a later stage with the addition of, retainer straps and filler caps from the brass etch included in this great kit.Pic 8
So this is where I am at the moment. Pic 9
From here on for a while I will have a shed load of small etch parts to work with.
The airframe, will be about 35-40 pages of instructions later on.
So, I`m back up and running with this one.
Watch this space,LOL LOL
#144 Posted : 31 October 2014 19:16:36
#145 Posted : 31 October 2014 19:33:31
stevie_o wrote:
been looking forward to you getting back at this one DelBigGrin Looking good.
Hi Steve, BigGrin Cool
This is one heck of a kit.
To that end I was not prepared to carry on with it, until, all of the other stuff was out of the way.
Life has now returned to some sort of normality.
Will update as soon as poss, but be prepared for some serious amount of etch bending as this kit is full of it, Flapper Flapper .
#146 Posted : 31 October 2014 20:09:27
BigGrin Glad to see your back on the build DelCool
#147 Posted : 31 October 2014 20:12:34
Cheers ARP, BigGrin BigGrin
What`s coming up in the build info looks incredible.
Just hope I can do it the justice it deserves,Confused Confused
#148 Posted : 01 November 2014 10:24:35
Hi Derek, if what you have produced so far is anything to go by them I'm postive what follows will be given the justice it deserves.... you're doing a cracking job, she's looking fab....Drool Drool
#149 Posted : 01 November 2014 10:29:14
Derek,
Hope you have a bit more time now to set your mind to your builds it must have been a upheaval to say the least. I have been looking forward to seeing more of this build it's all looking good and thanks for posting.
Trev.
#150 Posted : 01 November 2014 10:39:33
Hi Alan,BigGrin
Thanks for the vote of confidence.
I will as always do the best I can.
Thanks for looking in.
#151 Posted : 01 November 2014 10:47:39
tf64 wrote:
Derek,
Trev.
Hi Trev
Time is now on my side at last. BigGrin
Central heating done
Windows done
Leaking toilet cistern replaced
Leaking washing machine replaced
Only the remedial decorating to do,
but I've been given time off for good behaviour
LOL LOL LOL
#152 Posted : 07 November 2014 20:45:46
Here we are with the latest update.
A minor amount of construction with a fair bit of painting.
Firstly the construction of the bomb aiming window control handle.
Now according to the instructions, this is real accuracy.
The bend in the brass rod should be 171 degrees, I`ll let you judge Confused
The control head is constructed from six separate parts, just forgot to photo before
construction. Blushing Blushing
Anyway here`s the resultant part. Pic 1
The control gear and the upper bomb window frame are then painted.Pic 2
Along with the two previous parts, you add the acetate window and you have the bomb aiming window complete. Pic 3
The next job is to layer up the pilot`s control panel.
This consists of the back plate, adhesive dial transfer,acetate panel and then the top plate.
More minute detail still has to be added to the panel surface, in the way of buttons, switches
and control levers but that`s for later.
So here we are before the megga detailing. Pic 4
So, just another paint job on the rear gunners seat, yeah you guessed it, "BLACK". Pic 5
LOL LOL LOL LOL LOL LOL LOL LOL LOL
This is where we are at the moment. Pic 6
What`s to come?
Pilot seat pads
Pilots seat belts
Control panel detailing
Oil tank retainer straps and filler caps.
Then issue 22:
This forms the pilots control panel mounting plate
Plus, some box sections for some more of the control gear.Pic 7
Well, "That`s all folks", for know anyway.
Suffice to say that this kit is a joy to build.
Happy building,
#153 Posted : 07 November 2014 21:04:44
#154 Posted : 07 November 2014 21:08:56
stevie_o wrote:
Brilliant, loving this Del. The seats and instruments look fab, cant wait see moreBigGrin
Cheers Steve, BigGrin BigGrin
I`m loving this build.
The detail to come is amazing, but you have to make sure it doesn`t drag you along too fast so you make mistakes.
Thanks for looking in and the comments.
#155 Posted : 07 November 2014 23:11:12
Looking great Del, really enjoying your build of this one... Drool Drool . Incredible detail that looks as if a lot of patience is required to make it a success.... So looking forward to your next instalment.... Love Love
dandare
#156 Posted : 08 November 2014 00:50:49
loving the build Del
wish i had one of these Drool Love
doing a fantastic job
Dan
#157 Posted : 08 November 2014 12:27:49
This is a damn fine looking kit, going to enjoy following this
#158 Posted : 08 November 2014 15:02:44
Hi Alan, BigGrin BigGrin
Patience I need by the bucket load. This kit wants to drag you along at break neck speed, but I`ve got the brakes firmly on.
This is such a great kit it deserves real respect and that`s exactly what it`s gonna get.Cool
Thanks for looking in nad the comments.
#159 Posted : 08 November 2014 15:06:14
Dan
Hi Dan, BigGrin
These kits are about, but not cheap by any means and the instructions are in German.
#160 Posted : 08 November 2014 15:09:30
Hi Dave, BigGrin
Fine kit indeed Dave and you ain`t seen nothing yet.
Glad your enjoying it, makes for happy building when you have the support of members of the forum. Love
10 Pages «<678910>
