Hi Alan, Thank you for your time looking in and your comments more soon. Kind Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE:SPITFIRE. PACK 14 PARTS:52/55.  PARTS 52 ENGINE COVER FRAME 1 ENGINE COVER LATERAL STRUTS ENGINE COVER FRAMES 4/5 ENGINE COVER FRAMES 6/7  PARTS 53 ENGINE COVER FRAMES 2/3 WOODEN STRIPS 3X3X300 BAG OF NAILS  PARTS 54 LEADING EDGE 4 LEADING EDGE 5 TRAILING EDGE MACHINE GUN CANNON MACHINE GUN MAGAZINE  PARTS 55 LEADING EDGE 1 LEADING EDGE 2 LEADING EDGE 3 AWL Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev, looking forward to see you fitting these.... fab build.. Regards Alan
Thanks Alan, Received part 14 yesterday as above, so very keen to start to build the top engine cover look's like a lot of clamping? Will post today. Kind Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE:SPITFIRE PACK:14. Engine top cover. Pack 14 Contains parts to build the top cover for the engine compartment, I found that it was of basic construction, the only bit to watch was, keep checking that you have the correct alignment with the engine compartment this means lay it over a few times to see were you are and adjust. If you look at the pictures you can see that I built my top cover in place.  Cut out fret.  Replace fret sand smooth and mark up formers.  This is what is needed to make top cover  Clip side laterals in place ready for top formers.  Place and glue formers watch former G if the glue runs down it will stick to the main engine compartment.   A few more clips will help.   Sand all over.   Engine top cover removed. This is my way of building the top cover which I had no difficulty. Thanks for looking Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev, Spot on as usual, WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Lovely neat work Trev, cant wait to see more of this build Steve
Lovely work Trev
Thanks, Derek you will love this build. Steve, thanks for having a look, will be starting on the cockpit sides soon. Dave, thanks for your comments more soon. Regards to all Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Trev Another really interesting update to your build. It's all coming together very well. Happy Modelling
Impressive work Trev, love your methodology....  .. Keep it coming.... Regards Alan
Hello Tony, Just catching up,yes your right very interesting most of all how strong the air frame has become. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Alan, Thanks for looking, next job will be to complete the new jig for the metal plates, yes I have made two mock ups and binned em but number 3 looks good, time will tell, Kind Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Nicly done as always matey. “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Jase, Thanks for looking in, I will be starting on the leading edge soon that's the metal parts, just hope that they will fit my build just thinking about what type of glue to use as it is metal to wood, that's the last bits you don't want to fall off as they form part of the metal sheets. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE SPITFIRE BUILD: 221114. PACK 15 ISSUES 56 TO 59.  Stage 56.  Stage 57.  Stage 58.  Stage 59. This weekend I will be starting to build the leading edge let's hope that they will fit my build as metal would be hard to bend. Regards to all Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev, good luck with fitting the leading edge and plates... Judging by the quality of your build to date I'm sure you'll get the plates to fit just fine.....  .. Will be looking out for your next post.... Regards Alan
Thanks Alan,I will post this weekend. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Looking forward to seeing the metalwork go in J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
thanks Jase. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
