32 Pages «<1011121314>»
tf64 Spitfire Build Options
#221 Posted : 20 October 2014 21:37:35
Hi Alan,
Thank you for your time looking in and your comments more soon.
Kind Regards
Trev.
#222 Posted : 25 October 2014 18:55:41
UPDATE:SPITFIRE.
PACK 14
PARTS:52/55.
PARTS 52
ENGINE COVER FRAME 1
ENGINE COVER LATERAL STRUTS
ENGINE COVER FRAMES 4/5
ENGINE COVER FRAMES 6/7
PARTS 53
ENGINE COVER FRAMES 2/3
WOODEN STRIPS 3X3X300
BAG OF NAILS
PARTS 54
LEADING EDGE 4
LEADING EDGE 5
TRAILING EDGE
MACHINE GUN CANNON
MACHINE GUN MAGAZINE
PARTS 55
LEADING EDGE 1
LEADING EDGE 2
LEADING EDGE 3
AWL
#223 Posted : 26 October 2014 10:36:19
Hi Trev, looking forward to see you fitting these.... fab build.. Cool Cool
#224 Posted : 26 October 2014 12:12:28
Thanks Alan,
Received part 14 yesterday as above, so very keen to start to build the top engine cover look's like a lot of clamping? Will post today.
Kind Regards
Trev
#225 Posted : 26 October 2014 18:53:40
UPDATE:SPITFIRE
PACK:14.
Engine top cover.
Pack 14 Contains parts to build the top cover for the engine compartment, I found that it was of basic construction, the only bit to watch was, keep checking that you have the correct alignment with the engine compartment this means lay it over a few times to see were you are and adjust. If you look at the pictures you can see that I built my top cover in place.
Cut out fret.
Replace fret sand smooth and mark up formers.
This is what is needed to make top cover
Clip side laterals in place ready for top formers.
Place and glue formers watch former G if the glue runs down it will stick to the main engine compartment.
A few more clips will help.
Sand all over.
Engine top cover removed.
This is my way of building the top cover which I had no difficulty.
Thanks for looking
Trev.
#226 Posted : 26 October 2014 20:17:09
Hi Trev, BigGrin
Spot on as usual, WTG
Cool Cool Cool Cool Cool Cool
#227 Posted : 26 October 2014 21:00:27
#228 Posted : 26 October 2014 23:13:12
Lovely work Trev ThumpUp
#229 Posted : 27 October 2014 08:13:36
Thanks,
Derek you will love this build.
Steve, thanks for having a look, will be starting on the cockpit sides soon.
Dave, thanks for your comments more soon.
Regards to all
Trev.
#230 Posted : 27 October 2014 10:00:56
Trev
Another really interesting update to your build. It's all coming together very well.
#231 Posted : 27 October 2014 23:23:11
Impressive work Trev, love your methodology....Cool Cool .. Keep it coming....
#232 Posted : 30 October 2014 21:40:11
Hello Tony,
Just catching up,yes your right very interesting most of all how strong the air frame has become.
Trev.
#233 Posted : 30 October 2014 21:47:34
Hi Alan,
Thanks for looking, next job will be to complete the new jig for the metal plates, yes I have made two mock ups and binned em but number 3 looks good, time will tell,
Kind Regards
Trev.
#234 Posted : 30 October 2014 22:43:07
Nicly done as always matey.
#235 Posted : 21 November 2014 21:50:26
Hi Jase,
Thanks for looking in, I will be starting on the leading edge soon that's the metal parts, just hope that they will fit my build just thinking about what type of glue to use as it is metal to wood, that's the last bits you don't want to fall off as they form part of the metal sheets.
Trev.
#236 Posted : 22 November 2014 10:18:59
UPDATE SPITFIRE BUILD: 221114.
PACK 15
ISSUES 56 TO 59.
Stage 56.
Stage 57.
Stage 58.
Stage 59.
This weekend I will be starting to build the leading edge let's hope that they will fit my build as metal would be hard to bend.
Regards to all
Trev.
#237 Posted : 22 November 2014 10:26:41
Hi Trev, good luck with fitting the leading edge and plates... Judging by the quality of your build to date I'm sure you'll get the plates to fit just fine.....Cool Cool .. Will be looking out for your next post....
#238 Posted : 22 November 2014 10:38:20
Thanks Alan,I will post this weekend.
Regards Trev.
#239 Posted : 22 November 2014 13:41:18
Looking forward to seeing the metalwork go in
J
#240 Posted : 22 November 2014 18:51:58
thanks Jase.
This page was generated in 0.206 seconds.
