32 Pages «<910111213>»
tf64 Spitfire Build Options
#201 Posted : 07 September 2014 12:04:57
Hi Andy,
Thanks for looking in.
Trev.
#202 Posted : 07 September 2014 12:08:32
Hi Steve,
Thanks for your reply, would you believe it took all day Saturday to build that front end but all ok.
Trev.
#203 Posted : 07 September 2014 12:12:52
Hi Jase,
Thank you for dropping in, this is a great build more pictures to follow.
Trev.
#204 Posted : 07 September 2014 12:17:01
Hello Alan,
To me as I build the Spitfire that it has a solid feel about it, which can only be good for years to come because I am sure it will end up with the grandchildren !!
Trev.
#205 Posted : 07 September 2014 12:19:03
Hello Ponty,
Hope you are enjoying your build, and thanks for looking at my build.
Trev.
#206 Posted : 07 September 2014 12:26:01
Hi Tony,
Many thanks for taking a look at the Spitfire build, my thoughts are try and keep your build area as clean and unclutter as possible and it will follow through to your build.
Trev.
#207 Posted : 19 October 2014 12:43:10
UPDATE:SPITFIRE.
Engine Compartment.
My next job was to remove four cross bars from the top side of the engine compartment,the tools I will use are 20mm hand saw and a smooth hand file.
Also I will be fitting small reinforcements to the front part of the engine compartment.
These are the central bars I will remove from the fuselage assembly.
First I use my 20mm hand saw and very carefully cut through and removed each bar, the only point that I found that you must support the frame work to avoid a slip.
With all frame bars removed.
The next job is to smooth along the frames with a file and then sandpaper down to a smooth finish.
Next part reinforcements.
This picture shows two very small reinforcements removed from the fret, at this stage I left to sand when glued in.
With the two small reinforcements that I had with stage 48 the first job was to test fit and then glue, because of the size of these two frets I found it better to sand when dry.
Kind Regards,
Trev.
#208 Posted : 19 October 2014 13:12:04
Nice work Trev Cool
Be careful where you mount any additional reinforcements is the engine bay area, they may cause fit problems when it comes to mounting the motor mount and engine head.
#209 Posted : 19 October 2014 13:35:42
Hi Tom,
Thanks for looking, a very valid point with nose reinforcements I can see clearly from your pictures.
Kind Regards
Trev.
#210 Posted : 19 October 2014 14:33:29
Trev
Coming along really well.
That will look great with the spinning prop.
#211 Posted : 19 October 2014 16:25:36
Hi Trev, BigGrin BigGrin
Lovely work there, WTG Cool Cool
and thanks Mr T for giving us the little insight to what`s coming up.
Keep up the good work Trev.
Love Love Love Love Love
#212 Posted : 19 October 2014 19:31:50
BigGrin Nice work as always TrevCool
#213 Posted : 19 October 2014 19:37:52
dandare
#214 Posted : 19 October 2014 19:55:20
Trev
you make it look soooooo easy
a credit to your skills
really enjoying this build
Dan
#215 Posted : 19 October 2014 22:28:01
It's great to see some more lovely work from you Trev, she is certainly coming along very nicely...Cool Cool
#216 Posted : 20 October 2014 21:13:57
Tony,
Thank you for your comments that engine has to be very powerful to drive the metal prop (it's quite a weight )maybe it has a slow rotation.
Trev.
#217 Posted : 20 October 2014 21:18:13
Derek,
That was a great surprise from Mr T with the photos it shows the way ahead and the space we have to work with.
All the best,
Trev.
#218 Posted : 20 October 2014 21:19:27
Hi Andy,
Thank you for your support your always there.
Trev.
#219 Posted : 20 October 2014 21:32:29
Steve,
Thanks Steve I do like building aircraft and I have enjoyed building the Spitfire, I have been working on a jig to make the roller riveting more acceptable as I fear this will be a bit tricky and you only get one go at it.
Trev.
#220 Posted : 20 October 2014 21:35:14
Dan,
I thank you for your comments, I must say that your build looks to be a winner,keep posting.
Regard,
Trev.
