Best glue to use? Options
f13dfx
#1 Posted : 18 October 2014 18:27:44
Rank: Amateur Level 2
Red Medal: Red Medal
Hello All!
As mentioned, going to start my build Nov.6-22.
Wondering what would be the best glue to use (ie. Krazy Glue, Tamiya, etc.).
I tried the "Search" function in this forum but it didn't yield any results.Confused
#2 Posted : 18 October 2014 20:19:48
See post #6 of this topic, which our US support guy has recommended
http://forum.model-space...aspx?g=posts&t=7090
f13dfx
#3 Posted : 20 October 2014 06:03:30
I can only find the Touch-N-Flow Applicator in Sprue Brothers website.
I only found the Tenax 7R glue at Model Train Stuff's website.
Am I viewing the correct glue & applicator you are referring to?
experten
#4 Posted : 20 October 2014 14:22:01
Howdy,
The touch and flow folks are in Ontario, and here is a link;
http://www.flex-i-file.com/index.php
The Tenax I recommend has proven to be a bit hot for the touch and flow, and I think I failed to mention that when discussing it's use. (It does work, but if you forget and dont empty the touch and flow, you junk it.) Flex-i-file has a complete system they market.
The tenax works extremely well, and has been my go to cement for decades now. I most often apply it with a brush.
HTH!
Tired, Old, and Cranky!
f13dfx
#5 Posted : 21 October 2014 01:47:56
Thank you! Using a brush would make sense over continually filling/emptying a bottle/syringe.
experten wrote:
Howdy,
HTH!
f13dfx
#6 Posted : 03 November 2014 23:56:52
Does the TenaxR7 also work glueing Resin-to-Metal parts.
If not, what would be a recommended glue.
Thanks in advance!
Ponty
#7 Posted : 04 November 2014 01:12:27
Thanks in advance!
If memory serves me correct, the TenaxR7 is for ABS only. Super glue should do the trick. I use both a Gel version and the regular Loctite Super Glue(just be careful when using this as it flows very easy. You can use a toothpick, or something with a fine point to be more precise when applying)
Hope this helps
zuff
#8 Posted : 15 November 2014 22:09:43
Rank: Beginner Level 3
In the UK, Wilkinson hard plastic glue works superbly.
Stupot
#9 Posted : 16 November 2014 10:25:06
Yeah, Wilkinson or Wilko hard plastic glue is superb. It's probably the best glue i've ever used & it worked a treat on my McLaren. I'm not sure how you would get it over there though. Stu
NeilG
#10 Posted : 16 November 2014 12:47:21
Rank: Newbie
I use Tamiya Cement for ABS, ordered from ebay :-)
http://www.tamiya.com/english/products/87137cement_abs/index.htm
This page was generated in 0.110 seconds.
