Endeavour Longboat Options
catman275
#1 Posted : 20 August 2010 18:30:57
Hi all,
I have just finished my Endeavour Longboat and thought I would post some pictures of my first effort.
I am quite pleased with it although I can see several places which could do with improving.
One problem is the rudder which drops down below the keel, but the slots in it are level with the sternpost, which in turn, leaves the Tiller too low and drops into the rudder stems.
I consider this a fault in the design although the pictures in the instruction show it lined up slots and level with the keel.
I may rework this later.
The mast and boom material was supplied in 3mm thickness instead of 4mm.
I just bought some 4 mm dowel from my local supplier and stained it.
The rigging instructions were lacking as mentioned in an earlier thread.
I used the pictures on the DeAG page enlarged to see clearly for part of the rigging and very close study (and a magnifying glass) in the manual for the rest of it.
I was short changed with the amount of thread supplied, so it was fortunate that I did not make up the coils of rope as earlier instructed.
As it was I had to use some black thread I had at home for the anchor and some of the rigging.
All in all I enjoyed building this model and hope to embark on a more complex model later.
In the meantime I think I may scan and enlarge the plans of the parts say 50% and just attempt to cut/shape and build a bigger hull.
That should keep me quiet until next year.
Best wishes all
catman275 attached the following image(s):
completed..... Endeavour Longboat, San Francisco 2, Virginia 1819
building Royal Caroline
dtgray
#2 Posted : 20 August 2010 20:21:35
Very nice build catman, well done BigGrin Cool
David
snowtiger
#3 Posted : 21 August 2010 11:58:50
Top notch work there catman......a model to be proud of..BigGrin BigGrin
#4 Posted : 21 August 2010 12:15:37
Welcome to the world of artesania latina...LOL LOL
Your Build is very good m8. Well done on decifering the rigging instructions, I'm still working out the San Francisco 2 rigging plan.BigGrin
Only one comment though, When you do the rigging use a block of beeswax rubbed along the thread to get rid of the fluffiness of the thread. Other that that congratsBigGrin BigGrin BigGrin BigGrin
catman275
#5 Posted : 21 August 2010 20:34:52
Hi crew,
Thanks for the comments.
I can see there a lot of little tips and tricks to learn in this hobby.
Just out of a matter of interest there were a total of 15 blocks used in the rigging of this build.
How many blocks on the Victory?Scared Scared Have you a parts list yet?
happy planking catman
#6 Posted : 21 August 2010 20:56:23
I'm doing the hms surprise aswell which is a little bigger and on that one there are 445 small blocks,240 clump blocks plus more other blocks...
lee.takel
#7 Posted : 21 August 2010 21:21:28
Thanks for the beeswax tip magpie. Is it best to use this on all cordage ie the ropes for the anchor as well
#8 Posted : 21 August 2010 21:42:19
well done lee,nice model,the fluffiness on the cordage (all)can be pulled through a block of beeswax,victory has approx 1000 assorted blocks if you include the 5 boats on board. if all the guns were rigged as well well 104 cannons ????? i give up.
This page was generated in 0.201 seconds.
