Joined: 19/07/2014 Posts: 209 Points: 580 Location: Delecombe, Victoria, Australia
samson wrote:Hi Whizgig spot on dekking job werry autentik will be following this build . Cheers Samson Thanks very much for you comments Samson much appreciated. But I have to note that I made some mistakes that I will have to rectify, I put a line of nails by accident on pic 1 and 2 from the left row 8 at the center that should not be there and row 5 at the top from the left is crooked and the tenth board from the top after the cargo hold hole has been done as a 4 butt not a 3 butt and some of the short boards from the left have no nail holes the 1st 3rd & 5th boards from the bottom rear are missing nail holes and boards 1 & 3 at the rear top are also missing nail hols as well so if you are doing this take care and take photos and go over them with great care 2 or three times. I will have to make some sawdust mix and fill in the holes to hide the marks and then redo them properly. If anyone is interested I make it into a paste 1 part PVA wood glue to 1-2-3 parts sawdust of the same variety of wood I am using. Now depending on how dry I need the mix or how thin a coat i need. The rule of thump is the deeper or wider the gap the thicker or drier the mix needs to be if that helps anyone who wants to make and use it, it has may uses and is a trick of the trade to us cabinetmakers. I used this mix in my SOTS build on the small Launch which is here.Eugene.
Foz wrote:hi Whizgig very nice work on the decking, keep up the great work and keep the pics coming. Regards Foz  Thanks Foz.
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
Well done mate - looks really nice !!! You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
Joined: 17/02/2014 Posts: 124 Points: 376 Location: Wales, UK
Great work so far, a lovely looking kit
riff-raff wrote:Well done mate - looks really nice !!! Thanks For the comments Mate much appreciated.
cruorangelussilicis wrote:Great work so far, a lovely looking kit Thanks Mate!
Nicely done, looks really good
Thats a nice looking deck Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Great work Eugene, deck looks fab.... Regards Alan
Joined: 16/03/2014 Posts: 516 Points: 1,563 Location: Perth Western Australia
Hi Eugene. Popped in to see what you're up to with this build. It's all looking very professional mate. Regarding your sawdust and PVA fill. I used it myself early in the build when a clamp caused a depression. Good thing is once dry it sands down very smooth and better than filler in larger requirements. Keep up the great work. Will look in again as you progress. Regards George Building HMS SOTS
davetwin wrote:Nicely done, looks really good Thanks for your comments Dave Eugene
jase wrote:Thats a nice looking deck Jase Thanks Jase
Gandale wrote:Great work Eugene, deck looks fab.... Regards Alan Thanks Alan
George1 wrote:Hi Eugene. Popped in to see what you're up to with this build. It's all looking very professional mate. Regarding your sawdust and PVA fill. I used it myself early in the build when a clamp caused a depression. Good thing is once dry it sands down very smooth and better than filler in larger requirements. Keep up the great work. Will look in again as you progress. Regards George Yep it works a treat George and thanks for the encouragement.
Coming along very nicely Eugene, great work on the infills.... Regards Alan
Nice work there Eugene, should take a lot of hassle out of laying the planks. Definitely worth the effort. Well done Happy building David
Thanks Alan and David for your comments and encouragement Eugene..
