Eugene Top job there on your hull fairing. Especially impressed with your finish of those solid wood blocks on bow and stern because that is a difficult area to get correct. Can see this turning into a brilliant model at the rate your going - very well done. Happy Modelling
Whizgig wrote:Gandale wrote:She's looking good Eugene, well done on fairing the ribs.... didn't take as long as you thought, it is one of those jobs you're always happy to see finished.....  .. You'll be planking very soon now.... Regards Alan Thanks Alan, yep once I got stuck into it it seamed to go very quickly the plainer did most of the work and being in the chair had some advantage as the legs are a good platform to work on and to hold the hull while filing and planing. I do have one problem though the fore and aft blocks for the hull are solid and hard and you can't push the pins into it and it is hard to hammer them in as well so I think I am going to have to drill into them and then CA glue the pins in place to hold the planking on, I have brought the planking clips that Karl suggested and uses and I have made the ones out of the clips as well so I should be fine in that regard. Now I was thinking that I will do the planking in the traditional way without the infills as I have shaped the hull using one of the planks as a reference guide for shaping the ribs and I feel that it should be ok. Well the next step is to plank the decks and do the side rails then the planking of the hull is it best too: 1: Cut the planks to the correct length which is 125mm and then place them on the decking? 2: Glue the decking on then mark out the planks at the correct lengths with a pencil? Eugene. Hi Eugene, I find it always best to pre-drill the pin holes when planking, this way it helps to avoid bent pins but more importantly helps prevent splitting the planks and/or frames.... You don't have to use a drill bit, take a planking pin and cut the head off, insert that into your mini drill and you'll find it works just as well. When planking the deck I would mark the deck ply with guide lines 125mm apart then cut the planks to suit. A little slower this way but you will end up with a better finish. Do a small practice piece using both the methods you outlined and see for yourself which method gives you the look you are after... Hope this helps... Regards Alan
Joined: 19/07/2014 Posts: 209 Points: 580 Location: Delecombe, Victoria, Australia
davetwin wrote:Great job so far Eugene, she is really starting to take shape  Thanks for your comments Dave.
Thanks for that Alan I will give the drill bit a try using a push pin with the head cut off.
Hi Eugene, you're certainly powering ahead with this build and she looks to be coming along very nicely..... Will be following.... Regards Alan
 Lovely work m8 keep the pics coming  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
birdaj2 wrote:Eugene
Can see this turning into a brilliant model at the rate your going - very well done. A bit late on my reply mate sorry about that your post got lost in the rest of the posts, Thank you for your comments and yes they are a pain to do but the planer helped and did most of the work. It's a David brand here in Australia. David PlaneProduct Description For flat, concave and convex planing, cutting and scraping into every corner. A strong and effective mini plane, its dimensions are 106mm x 54mm and features a durable aluminium body. This palm size plane is always sharp because it has a disposable replaceable blade. When dull on both edges of the double-edge blade, you simply throw it away and insert a new blade. The replacement double sided blades are available seperately in a pack of ten. Supplied with 2 blades. It is a four-way, three position mini combination plane with adjustable cutting depth: Features: smoothing plane with blade in mid position corner plane with blade in front position shaping plane with blade in rear position for convex planing scraper blade with blade in front position This plane is also very popular in the surfboard manufacturing industry. Model ship builders are also regular buyers of this wood working plane.
Eugene Your going really well with your build. Interesting mention of the David's plane and it being popular with surf board builders. I have one of these but have still to master it's use  you do have to keep that blade at the correct depth but even then I still struggle with it. Good to see it being used so well on your build. Happy Modelling
Some nice progress there Eugene Steve
stevie_o wrote:Some nice progress there Eugene Steve Thanks Steve. Eugene.
birdaj2 wrote:Eugene Your going really well with your build. Interesting mention of the David's plane and it being popular with surf board builders. I have one of these but have still to master it's use  you do have to keep that blade at the correct depth but even then I still struggle with it. Good to see it being used so well on your build. Well I am used to hand planing so I guess that helps. Eugene.
Hi Eugene, You're really getting stuck into this build now, lovely work. I like the detail that's going into the decking. Think you made a good choice on the method. Look forward to next update. Happy building David
daffy09 wrote:Hi Eugene, You're really getting stuck into this build now, lovely work. I like the detail that's going into the decking. Think you made a good choice on the method. Look forward to next update. Happy building David Thanks for your comments David very much appreciated. Eugene.
Looking good Eugene, looking good.... Regards Alan
Joined: 24/02/2013 Posts: 212 Points: 632 Location: denmark
Hi Whizgig spot on dekking job werry autentik will be following this build . Cheers Samson
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
hi Whizgig very nice work on the decking, keep up the great work and keep the pics coming. Regards Foz
