5 Pages <1234>»
Rob's Victory Build Options
daffy09
#21 Posted : 21 March 2014 14:45:39
Hi Zepp,
Lovely work you're doing there. Like the idea you had for the pins - nice oneBigGrin. Another tip you may find useful if you're using the plank bender/crimper is to remove the blade and turn it around so as to use the flat edge rather than the blade. That way you will still get a good crimp but won't accidentally cut right through the plank. Brilliant job on the launch.
Happy building
David
Hans
#22 Posted : 25 March 2014 12:00:28
Well done rob. She looks really good. I think a masterpiece is in the making. Good job.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
zepp
#23 Posted : 27 April 2014 08:45:06
Rank: Amateur Level 1
Thanks again everyone for all the positive comments! David, I tried your tip of turning the blade around in the plank bender but I found it squashed/crushed the plank too much. I've gotten used to using the sharp side now and applying just the right amount of pressure. I think I only accidentally cut through 2 or 3 planks early on in the process, and haven't done one since! BigGrin
Been so busy recently so I haven't had much time to work on the model, but I have managed to get the first lot of gun ports done! May take me a few or more years to finish this Blink lol, but I am enjoying the process immensely
I found drilling four holes for each port then rough sawing them and finishing them off by pairing with the x-acto knife much easier/quicker than the method used in the magazine!
Also, only 8 or so weeks to go before I finally get to go see the victory again for real! Does anyone know if all the masts are currently up on the Victory?
When I went 2 years ago, they were off, lying on the dock beside the ship (I assume for maintenance?). I'm hoping to get photos with them up this time!
Give quiche a chance!
My Victory build
#24 Posted : 27 April 2014 09:38:04
BigGrin Hi Zep
Looking good there , as for your question about the Victory one of out members went there a couple of weeks back and its would seem the masts are still off due to the major refurb going on there
jonny7england
#25 Posted : 27 April 2014 10:09:09
Hi Zepp...Very nice work!!! Smile ThumpUp
#26 Posted : 27 April 2014 10:18:15
Hi
Looking really goodCool enjoying your build, keep the pics coming
#27 Posted : 27 April 2014 14:20:54
Lovely neat work Rob, your patience is certainly paying off.
Nice way of doing the gunports and if it works for you then go for it, but...
The idea of making the center hole as per the magazine build is to make sure that the dummy gun barrel has a nice centred hole in the support. Doing it your way will mean you now have to find the centre by eye that's all. Perhaps on the next row you may want to drill the centre hole first and follow through to the support, then continue with your corner hole solution?
zepp
#28 Posted : 28 April 2014 12:35:56
Hi Steve, Yeah I realise the way it's done in the magazine is so you have a central hole for the dummy guns, but I really don't trust my drilling to remain straight for those holes after going through the planking BigGrin LOL
Instead I plan on making a timber block jig around 25mm long, 12mm x 12mm square with a hole down the centre which i can put into the cutouts so it rests against the beam inside and guide the drill bit to ensure all dummy gun holes will be central! hopefully it works BigGrin
My Victory build
#29 Posted : 28 April 2014 14:04:52
thats an interesting Idea and will also prove your ports are square and all the same size.
J
#30 Posted : 28 April 2014 15:45:11
Thought you would have had a planBigGrin I remember seeing the same block idea used on a victory build on here somewhere, but it was too late for me to use at the time.
I'm sure it worked perfectly though.
zepp
#31 Posted : 23 September 2014 13:50:23
Been a while since I posted an update. Been slow going on my build until a few weeks ago, But I'm getting back into it now.
Went on a 2 month holiday to the UK and Europe a few months ago and managed to visit the historic dockyard at Portsmouth and go on board the Victory! Was a lovely day and an amazing experience!(even if the full masts were still down for renovations)
Some progress shots of my build.
My Victory build
#32 Posted : 23 September 2014 15:39:29
Rob
That is the exact point I have reached in my build but again with so many other life issues at the moment is not progressed any further for a few weeks.
Very nice work your doing on yours and that planking looks very smooth.
#33 Posted : 23 September 2014 20:07:11
z8000783
#34 Posted : 23 September 2014 21:22:35
Groups: Unapproved
That will rub done really well.
cruorangelussilicis
#35 Posted : 23 September 2014 21:46:06
Lovely work, that sand down really makes a difference too, can't wait to do mine!
#36 Posted : 23 September 2014 22:42:46
Great work with the planking Rob, lovely and neat.... very well done... Cool Cool
zepp
#37 Posted : 15 February 2016 12:34:21
Well, between changing jobs, dislocating my shoulder and requiring reconstructive surgery to fix it, it has definitely been way too long since I posted an update. Although I haven't really made a massive amount of progress. But I suppose It doesn't hurt to show some incremental pictures? BigGrin
Really enjoying the planking of the lower part of the hull, although the curve needed for the planks at the stern have definitely been a challenge!! Such a shame I'm going to cover all that hard work with copper tiles. LOL
Finally up to the last 10 rows of planks and issue 38! Cant wait to finally get the hull completely planked :)
My Victory build
#38 Posted : 15 February 2016 13:02:38
BigGrin Very nice job on the planking Rob Cool I hope the shoulder is better Cool
z8000783
#39 Posted : 15 February 2016 13:25:51
Groups: Unapproved
Fabulous work Rob. Are you sure you want to copper? Stain would look wonderful of this quality planking.
#40 Posted : 15 February 2016 14:52:47
Rob
Not always easy to pick up a huild after a long period away but you have managed to very well and the planking looks great.
5 Pages <1234>»
This page was generated in 0.381 seconds.
