27 Pages «<24252627>
George1 Build Options
George1
#501 Posted : 18 September 2014 03:59:10
George1 wrote:
Hi George, really sorry to hear you are looking to delay the SOTS build further until after your summer is over.. Can understand and appreciate your reasons fully why and it must be really disappointing for you..... Be careful though, just as Jonny has mentioned, try and find somewhere in the house to store your build that will remain a constant temperature to avoid any potential warping damage due to temperature variations...Cool Cool.. Would it not be possible to carry out some of the build outdoors but in a shaded spot or is the temperature outside also unbearable??.... Great idea to take up the Spitfire and hope to be following your build diary on this very iconic aircraft.... Take care and look forward to seeing more progress on the SOTS after xmas....
Hi Alan. BigGrin
Will still carry on with Sots for now. Sorry if I gave impression of an immediate stop. BigGrin
Yes, re storage when I do stop is something I've been looking at. Funny enough even in the house it is not an easy task to find such storage area. We really need another room. Laugh Obviously I will have to overcome the problem. BigGrin
Re the "Spitfire" I will try to budget for it so I can go from one to the other smoothly. I can use my den to build it as I did originally with SOTS till the mess started to build up then had to move to garage. It doesn't appear to be quite as much in the way of sanding etc. BigGrin
George
Hi George, no matter what you decide to do whether on the SOTS or the spitfire I will be following your progress all the way.... Do hope you are able to continue with the SOTS even if it means doing some of the messy work outdoors..... Your decision and whatever way you go I will respect and understand..... Cool Cool .. One thing we always say with these builds is it's not a race but a passionate journey so do what you can, when you can but most of all enjoy it......Cool Cool
Best regards
Hi Alan.BigGrin
I now see where as you've said previously that there were planks left over or if you like planks excess to requirements. BigGrin
Issues 27 and 28 which I will pick up today are both planks pins etc. They will now be in excess as when 29 and 30 arrive there is no planking till these are fitted then 31 is planks again. BigGrin
Looking at this situation in its best light at least the best of the planks can be utilized instead of trying to use all planks regardless of their state cut to shorter lengths etc., as have done up till now.BigGrin
This is not a moan just I can see where your earlier info on excess planks came from. BigGrin
George
Building HMS SOTS
fredsmit
#502 Posted : 21 September 2014 19:21:06
Excess planks are evil and makes me want to build ahead. Must resist. 10/10 with the planking George, looks really good.
Current Builds:
Sovereign of the Seas
The Black Pearl
Amati Adventure Pirate Ship
George1
#503 Posted : 22 September 2014 02:01:22
Hi Fred. BigGrin
Thanks for the 10/10 it's greatly appreciated while really it should be more like 7-8/10. Laugh
While the situation re issues has held me up regards not being able to do more till 29-30 arrive the excess as I said will at least allow more choice of best planks to use. BigGrin
Plenty of builds to follow if wanting to move ahead. Most UK builders of SOTS now into their second year of build.BigGrin
George
Building HMS SOTS
George1
#504 Posted : 06 October 2014 12:52:40
Pics up to issue 30.BigGrin
Stern section and dummy cannon supports and painted black. BigGrin
NOTE: If you haven't yet done this section. The dummy cannon supports come in three widths. The instructions are to cut the widest supports at 248 mm long then various measurements re the half way through cuts. I found that this length was 10 mm overhang past second last rib before stern section where a short 41 mm piece from cut off second widest support goes in to finish off. So had to cut to 238 mm to fit half way through that rib for short piece to fit at halfway through rib and into stern area.BigGrin
Obviously follow the instructions, but only dry fit first and if like me you find 10 mm overhang cut to the 238 mm length instead.The half way through cuts are correct still on this piece. BigGrin
George
Building HMS SOTS
Whizgig
#505 Posted : 06 October 2014 13:42:00
Looks bonza George you are coming along with this nicely. SweetBigGrin
Eugene.
#506 Posted : 06 October 2014 19:15:12
BigGrin Nice work on the planking GeorgeCool
#507 Posted : 06 October 2014 19:34:13
#508 Posted : 06 October 2014 21:29:03
Hi George, BigGrin BigGrin
Bang on mate WTG,
Cool Cool Cool Cool Cool Cool
#509 Posted : 06 October 2014 23:26:52
She's looking fab George, your patience is paying off and you are spot on regarding the length (238mm) for the dummy gun support running to the stern.. This discrepancy was also pointed out on Mr T's official build which confirms your findings....Cool Cool .. Keep up the great work you are doing and I look forward to your next post....Cool Cool
George1
#510 Posted : 07 October 2014 01:50:22
Eugene.
Hi Eugene. BigGrin
Thanks for compliments they are appreciated mate. Cool Cool
Hopefully now I can surge ahead re planking upper area. BigGrin
George
Building HMS SOTS
George1
#511 Posted : 07 October 2014 01:51:52
Hi Andy. BigGrin
Thanks for looking in and your compliments. As always appreciated. Cool Cool
George
Building HMS SOTS
George1
#512 Posted : 07 October 2014 01:53:50
stevie_o wrote:
Nice work George, very smoothBigGrin
Hi Steve. BigGrin
Appreciate your kind words. As always they are very much appreciated.Cool Cool
George
Building HMS SOTS
George1
#513 Posted : 07 October 2014 01:56:09
Bang on mate WTG,
Hi Derek. BigGrin
Thanks for looking in and your kind words. They are always appreciated.Cool Cool
George
Building HMS SOTS
George1
#514 Posted : 07 October 2014 02:01:15
Hi Alan. BigGrin
Thanks for your nice compliments. They are as always greatly appreciated. Cool Cool
Yes re the 238-248 mm length I did wonder at such a discrepancy so glad I was right. BigGrin Or starting to think my build 10 mm short.Laugh
George
Building HMS SOTS
#515 Posted : 07 October 2014 09:47:16
BigGrin Nice work on the planking George looking good Cool Rgd Martyn
George1
#516 Posted : 07 October 2014 13:52:35
Hi Martyn. BigGrin
Thanks for looking in and your kind words. As always it is greatly appreciated. Cool Cool
George.
Building HMS SOTS
George1
#517 Posted : 08 October 2014 08:37:23
Alan if you happen to look in. BigGrin
I notice that the very rear of the ship's gallery juts out some 1/2 mm from the plank below. I checked your build and it looks to be the same. Now the first plank from bow to stern that has to be laid next covers that small gap between the last plank and ship's gallery. Do you need to shave level with plank below or does the plank end jut out just that little bit a that point Confused
Appreciate your thoughts before I start upper planking. BigGrin
George
Building HMS SOTS
#518 Posted : 08 October 2014 09:50:55
George
You have really progressed at a pace with this one and produced a very good looking hull.
Very well done
#519 Posted : 08 October 2014 22:39:19
George
Hi George, think I follow your concerns here. Don't worry about how far the plank extends beyond the stern, I left that plank a little longer, 2mm I think and you will find later in the build you will trim that plank down but don't do it yet, you need the overhang.. Have a look at Mr T's Official build issue 33, the final couple of photo's should make it all clear to you.....Cool Cool .. Hope this answers you question, if not then do get back to me..
George1
#520 Posted : 09 October 2014 02:25:42
birdaj2 wrote:
George
Very well done
Hi Tony. BigGrin
Appreciated you looking in and the kind comments. Cool Cool
It's getting there. BigGrin
George
Building HMS SOTS
This page was generated in 0.391 seconds.
