Rear wheel camber on RB7 Options
doddy12
#1 Posted : 11 September 2014 09:38:23
I have just fitted both rear wheels to my RB7 and have noticed that there seems to be a quite extreme camber.
Both sides are pointing in at the top at an angle i wouldn't have expected.
I have double checked my build process but cant see any mistakes on my behalf.
Has anyone else found this?
kenjara
#2 Posted : 11 September 2014 09:48:52
Have you got a photo?
You probably have some of the linkages at the wrong length.
its normal for rear wheels to have a little toe-in.
#3 Posted : 11 September 2014 09:54:43
Check the rear hubs with the instructions for each, are correctly oriented and are correct for each side of the model.
doddy12
#4 Posted : 11 September 2014 10:45:29
I have had a look and can't see how I could have mixed them up.
I notice that when I rotate the wheels one side of the drive shaft almost comes out of the housing.
I will attach a pic shortly.
doddy12
#5 Posted : 11 September 2014 12:51:03
Whoopsy.... Had the left and right hubs 180 degrees out. The bottom fixing was on the inside instead of out and subsequently pushed the bottom of the hub out.
Dont i feel stupid!!
Blushing Blushing Mad
#6 Posted : 11 September 2014 13:01:34
Here is a pic of mine, where you can see that the bottom mount tab is wheel side rather than facing inside.
doddy12
#7 Posted : 11 September 2014 13:17:19
Thanks so much. I saw the error of my ways just after i uploaded the pic.
75% done. cant wait!!
This page was generated in 0.167 seconds.
