A question of pins Options
Allan
#1 Posted : 18 August 2010 09:05:11
Reference the pins and the pin pushing tool how far do you push the pins in as i dont want to start digging the heads out there is obviously some parts that don't matter how far in they go as it will not affect the build later on????
also what is the diameter of the trenails is used?????
#2 Posted : 18 August 2010 10:06:22
allan,as a rule,internal structure no matter ;bout pins,bury them if you like,external I would not use pin pusher,leave heads of pins about 1mm.showing.I have tried pin pusher but find the irish screwdriver much better,I also predrill holes before I hammer them.less prone to bending that way.As for the trenails,you mean the floorboard nails?,as small as you can get them,I use cocktail sticks,I can get 'bout 8 out of 1 stick.
captainalan
#3 Posted : 18 August 2010 20:31:51
i was thinking of using cocktail sticks for the planking both deck an hull
ive seen it in other models, and it looks so right
any idea's anyone?
Allan
#4 Posted : 20 August 2010 16:07:06
as cocktail sticks are 2mm in diameter what will the width of the deck planks be ?????
piot007
#5 Posted : 20 August 2010 20:23:49
Have a look at Karl1113's build diary. In there he expertly explains how to 'shave' them down. Prob needs 0.5mm drill bit for this though. (it blew my mind that i could get bits that small! LOL )
This page was generated in 0.089 seconds.
