Fairing the Hull Options
IAN
#1 Posted : 17 August 2010 13:48:06
Hi All...
>>Fairing of the hull - This is fully covered in the magazine, its a time consuming process which is to prepare the hull for planking, its particularly important at the bow and stern to form a smooth curve, and the width of the keel at the stern is thinned to 2mm (but do not chamfer its edges), <<
Do you think we will be supplied with a template for the correct curve?
Ian
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
doremi495
#2 Posted : 17 August 2010 14:40:49
In a word NO. If you read Tomicks official build pages he suggests, and I do, that you use a thin plank to check the curve of the hull at bow and stern, making sure that the plank touches as much of each rib as possible.
Dave H
Current builds :- Hachette 1/16 Tiger Tank
H.M.S Victory, Santisima Trinidad (Section), 1/8 scale Aston Martin DB5, 1/8 scale McLaren, YNWA
#3 Posted : 17 August 2010 16:25:56
The tips of issue 20 also recommends the use of a plank as a fairing check.
This page was generated in 0.087 seconds.
