Joined: 29/03/2010 Posts: 190 Points: 512 Location: Lytham UK
Hi All... >>Fairing of the hull - This is fully covered in the magazine, its a time consuming process which is to prepare the hull for planking, its particularly important at the bow and stern to form a smooth curve, and the width of the keel at the stern is thinned to 2mm (but do not chamfer its edges), << Do you think we will be supplied with a template for the correct curve? Regards, Ian Ian Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas Wish list: Bentley Blower http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
Joined: 20/03/2010 Posts: 226 Points: 647 Location: Merseyside
In a word NO. If you read Tomicks official build pages he suggests, and I do, that you use a thin plank to check the curve of the hull at bow and stern, making sure that the plank touches as much of each rib as possible. Dave H
Current builds :- Hachette 1/16 Tiger Tank H.M.S Victory, Santisima Trinidad (Section), 1/8 scale Aston Martin DB5, 1/8 scale McLaren, YNWA
The tips of issue 20 also recommends the use of a plank as a fairing check.
