Stage 28 The Valve Gear-Adjusting Eccentric Arm Options
crbc54
#1 Posted : 23 August 2014 13:30:03
Hi All,Just a quick bit of advice needed.In the final part of fitting the valve gear it says adjust the position of the left eccentric arm so that it is angled about 10 degrees away from the vertical line.Do I do exactly the same with right eccentric arm ie position the right wheel as in the picture and fix arm 10 degrees off vertical,Many thanks,Clive
Gary O
#2 Posted : 23 August 2014 13:34:33
It should be a mirror image of the left side.....10 degrees toward the front.
D51, Senna McLaren. Pocher Alfa Romeo 8C-2300 Monza 1931 1/8 scale. Pocher Lamborghini Aventador white roadster.Tamiya 1/12 Ferrari Enzo. Toyota GT2000.
swordfish fairey
#3 Posted : 29 August 2014 15:35:54
This may give you some idea.........
This page was generated in 0.082 seconds.
